queen of spades
- Joined
- Jul 9, 2008
- Messages
- 144
I noticed a small drip under the back end of my 1601d a couple months ago but couldn't find where it was coming from. Now that I've used the tractor a bit more (and used it in dusty conditions last weekend) I have a better idea, but I am still not completely sure. The leak is definitely worse now.
By looking at these pictures can anyone tell where this leak is likely coming from?
where it's leaking on my trailer (it stays on here all the time except when I'm using)
from the back looking down at the tow hitch
the 4wd shaft - this black thing leaks a little, but this is different from the leak in the back. the oil does not run all the way down along the length of the drive shaft. It's only damp around the rubber seal here:
another:
ok the next few were taken up under the tractor looking up at the left side of the rear end (axle?). they were taken from the middle of the tractor looking back.
this is also the left side, but looking forward from the rear
here is the right side for comparison
The tractor is still under warranty but the dealer needs to know where the leak is coming from before they will do anything (I live 4 hours away from them, so it's not practical to just load up and drive 8 hours round trip). They kindly offered to let someone local work on it if I can find out where this leak is coming from. I don't have heavy equipment or jacks to take apart a rear end.
I know there are two, the drive shaft seal (the first two pics) is clear, but the leak in the back is giving me fits.
Thanks for any help.
another:
