Ok, I finally got around to pulling my fuel filter. It started leaking all of a sudden and I need to fix it.
Now the filter makes sense, but what is the top "hole' and hose for? The attached filter shows an inlet on the right, outlet on the left. The lower hole is used to attach the filter to the block. The upper hole is what is leaking, there is small hole that goes into the filter. The upper hole has a spring loaded assembly and a line comming out that appears to be an over flow of some sort since it went nowhere on my tractor.
