professor
Gold Member
- Joined
- Apr 13, 2002
- Messages
- 335
- Location
- jackson tn
- Tractor
- Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
I was servicing my 1401 Monday and before changing oil I let the tractor run until warm. As the oil was draining I checked the radiator coolant. When I opened the cap I noticed foam. The coolant was clear with no oil and the oil did not have coolant in it. I saw no bubbles but when the tractor is running you can see the coolant circulating in the radiatir which I assume is because of the water pump. The tractor runs good but I have never seen the coolant foam in this tractor. There is no over flow in the recovery container. Do you think I have problems with the head? Thanks for any information you can give me.
