lragan
Member
After running my F20D for several hours, I had difficulty starting it again. If I waited till the next morning it would start right up. I changed the fuel filter and it started and died after 5-10 seconds, so I thought I had air in the lines. This morning, I tried clearing the injector lines by loosening the injectors one at a time while cranking the motor to push the air out. First injector seemed to push the air out o.k., but when I opened the second I could not get any fuel to spurt out while cranking the motor. I don't actually remove the injector but rather loosen the nut that holds it in place. Should I completely remove the line while cranking and can the injectors get clogged?
