HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Brand Specific Forums > Yanmar
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-31-2009, 04:45 PM   #11 (permalink)
MJPetersen's Avatar
Send a message via Skype™ to MJPetersen
Default Re: 1510 D Upper lift arm broke
Quote:
Originally Posted by tallyho8 View Post
Mike
That is a very nice basic trailer for your purposes. I wondered why you did not weld 2 uprights to your front crossbar to help hold the logs and make loading easier.
I was going to put some uprights there for that purpose, but I have a picture in my mind that I would like to make the little trailer more versatile similar to the Nova Jack trailers with removable uprights. I thought about welding something on temporarily like the uprights protecting the wheels, but decided not to for now. I want to put a hand winch, a boom, the uprights and a dump box. We will see how much of it gets made in the near future.
Mike
__________________
"In all your ways acknowledge Him and He will direct your paths." Solomon
YM1510D, YM 1202 tiller, The following home made tools: Quick Hitch, KK copy dirt scoop, imitation Gannon rollover box blade, Forks on 3pt, and a Rear Blade with gauge wheels
MJPetersen is online now   Reply With Quote
Old 10-31-2009, 11:04 PM   #12 (permalink)
tallyho8's Avatar
Location: Katrinaville LA west of Westwego east of Ama south of River Ridge north of Boutte, above sea level
You could just use a 2" piece of channel like your front crossmember is made of and weld it on sideways to the end of your crossmember and notch a 2x4 to go in it. Quick, easy, and removable.
__________________
Happy Trails!
tallyho8 is offline   Reply With Quote
Old 11-01-2009, 09:18 PM   #13 (permalink)
Member
Roonabeck's Avatar
My 1510's right upper lift arm was welded when I got it 3.5 years ago. Someone did a nice job on it, no reinforcement, and it's not very noticeable. I've been going to replace it sometime, but it's held up fine against my finish mower and box of rocks (loader counterweight) for this long, so maybe not.
Roonabeck is offline   Reply With Quote
Old 11-02-2009, 02:20 AM   #14 (permalink)
MJPetersen's Avatar
Talley, That is a good idea. I was thinking in terms of metal and I do not have any material that I have found in my collection that would be appropriate. I will have to go look at my collection again with a different perspective.
Roonabeck, Mine broke in the exact same place on the left side. The guy that welded it up for me did a very good job, but he was not confident in it so he went the extra and put a piece on top and another on the bottom. Each piece is 10 mm thick (between 3/8 and 7/16) so it should be super strong. I did order another one because for me it would be hard to get and I continually am working the 3 pt against the relief.
Mike
__________________
Old 11-04-2009, 09:36 AM   #15 (permalink)
Smoody's Avatar
MJ, just curious as to why you haven't upgraded to a larger Yanmar? If you are always pushing the 3point to its limits, you may could benefit from a larger tractor.
Smoody is offline   Reply With Quote
Old 11-04-2009, 01:55 PM   #16 (permalink)
MJPetersen's Avatar
Quote:
I really do not want a larger tractor--Even working in the forest and along the trails a bigger tractor just would not work--I do not really have room for a larger tractor.
I am going to get a gauge and check the pressure on the 3 pt. The relief may be set too low. There are times that I definitely benefit from a larger tractor, but there are other times when a larger tractor just would not work. So I use the smaller tractor for all needs.
I considered a 1610 D, that is for sale here in Poland for a reasonable price, but the 1610 is about 40 cm (16 inches) longer and that would be a severe handicap in maneuverability in tight spots.
Mike
__________________
Old 11-04-2009, 02:24 PM   #17 (permalink)
California's Avatar
When you gather firewood are you going into the forest, greenbelt, via foot-paths?
Then a tractor this size makes sense. It's nearly as maneuverable in tight spaces as a horse.
__________________
1981 Yanmar YM240 photos
California is offline   Reply With Quote
Old 11-04-2009, 05:10 PM   #18 (permalink)
MJPetersen's Avatar
That is it exactly California--It is a greenbelt along a creek that only has foot paths--and sometimes not even that. : I really need the narrow width and ability to weave around trees. In my case one-size must fit all.
Mike
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.23543 seconds with 9 queries
