Smoody
I noticed a fuel/burning smell while using the YM2210 today, I thought it may be running hot but after inspection I noticed there was fuel slightly leaking out the rubber fuel line that comes off the top of the fuel tank where it connects to the injector. It also seems to drip when enough builds up here, the rubber hose slips off VERY easy, its not tight, it has a yellow pull tie on it but fuel seems to seep its way out a little at a time..My question is, is this loose rubber hose the main cause of the leak or is it something more? notice where I mention a SMALL amount of bubbling in the lower part of the photo, is the gasket leaking or is that where the fuel is burning off resulting in the smell i smell?? how can I stop this from leaking?
I think its the rubber hose leaking where it connects, but when I noticed the bubbling I thought it may be more, tractor cranks and runs fine, no power loss or anything. Thanks for the help
