wiring ym240
   / wiring ym240 #1
jbrd
Member
East San Diego County, Ca.
B7800 & Ym240
anyone know the way to rout the wires to the dash, and the proper location for the voltage regulator for the ym240? I have a new fuse box, has anyone rigged up a waterproof backing for this new fuse box? Thanks, jbrd
   / wiring ym240 #2
hello and welcome to TBN. You can find lots of info here and I am sure that a member named "California" will post a pic of what you need shortly. He has a 240. I will give you a wiring diagram of a 240 that has been posted a few times. Almost always the voltage regulator goes on the left side of the firewall.
Mike
   / wiring ym240
Thanks for the response. After you replied I found the two bolt holes that matched the regulator on the left side of the firewall. Thanks for the wiring diagram. Your tractor looks much nicer than the one I'm working on. It does sound like a simple problem,but routing the wires to the dash so they don't get dinged up is a real head scratcher for me. Thanks again, jbrd
   / wiring ym240
California, That would be a great help for me. I will try to get squared away on sending photos if you'd like to see what I'm dealing with. Thanks, jbrd
   / wiring ym240 #6
Here you go. I left the photo huge, so you can see some of the wire trace colors if you scroll around in it.
Comments on mine:
I don't know what that wire is, that comes out of the steering column and ends in an un-connected male connector.
I remember now that one of my initial renovations upon purchase was to put individual glass fuses in place of the taped-up mess I found on the fuse panel. That is the original fuse panel (with cover missing) that everything is connected to.
Horn and (missing) turn signals don't work. Headlights, charging and starting system, and dash idiot lights work properly.
   / wiring ym240
Thanks, that really helps, I put the voltage regulator right where yours is, and I'm going to put the new fuse box where the old one was as in your picture, the wiring to the new fuse box enters the back so I'm going to make a bracket to bring it out an inch or so from the fuel tank. If you're ever around Julian I'll buy you a pie. Thanks again, jbrd
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2006 TerraGator 8104 (A55314)
2006 TerraGator...
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
2016 Kia Soul SUV (A55853)
2016 Kia Soul SUV...
