Results 1 to 7 of 7
  1. #1
    Super Member Inspector507's Avatar
    Join Date
    Mar 2002
    Posts
    5,906
    Central Ohio
    Default Springy Seat
    Someone over at the *old* Yahoo Club said he uses old auto valve springs under his Yanmar seat to give it a little bounce. Not having any valve springs around, I stopped at the local military surplus dealer. He had just what I was looking for. I mounted them under the replacement seat for a little bit of spring when mowing.
    Attached Images Attached Images
  2. #2
    Elite Member
    Join Date
    Mar 2002
    Posts
    3,999
    Default Re: Springy Seat
    I did a similar thing using tapered exhaust manifold springs that you can find hanging on the rack in most autoparts stores. Just fit them right inside the existing rubber bumpers, and to protect the seat and make it look really profesional you can cut the bottom 1/4" off a pair of the proper size "rubber feet", I think they were 1 1/8", and fit them over the ends of the springs. I don't have access to my tractor right now or I would post a picture.
  3. #3
    Join Date
    Mar 2002
    Posts
    141
    Bonnieville Ky
    Yanmar 2310 and IH 3414 w/loader and 3100 backhoe
    I was planning on doing the same thing, but the front hinge weld broke, I tried to reweld it but to no avail. At my local NAPA dealer they were selling a tractor seat that I was able to mount on my 2310. It has two springs as well as a shock absorber. It also includes a back rest, and arm rests. I don't think it would fit a 1500- 1600 size, but 2000 and up it should be no problem. I had to drill new mounting holes and discard the old Yanmar mounts, but now I have a really confortable seat and mowing the field is even more pleasent.
  4. #4
    Join Date
    Mar 2002
    Posts
    885
    S Illinois
    Iseki TA 207
    I was the one on the Yahoo club that posted. Yours looks exactly like the way I do it. It really makes a difference. I have to do some other modifications to the newer models so the seat doesn't hit the metal around the draft control arm.
  5. #5
    Veteran Member EFC's Avatar
    Join Date
    Dec 2001
    Posts
    1,149
    Richland, Washington
    Enough
    Very cool [img]/w3tcompact/icons/grin.gif[/img]
  6. #6
    Join Date
    May 2002
    Posts
    21
    Jacksonville,FL
    YM2000BD
    I also put springs under the seat of mine. I had an old lawn tractor laying around that had springs under the seat. They bolted on without any problem,and what a difference they made compared to the stock rubber bumpers.
    Reid
  7. #7
    Join Date
    Mar 2002
    Posts
    5,906
    Central Ohio
    Reid,
    I looked at my lawn tractor and thought about ordering them from Sears, but the ones military surplus worked great. The Sears spring may have been a little easier to mount but, these work.
    Jerry
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
