Results 1 to 3 of 3
  1. #1
    Join Date
    Sep 2009
    Sand Springs, Ok.
    yanmar 1610D
    Default RS1400 guards/skirts. Need to fabricate a pair
    Tilled with my Rs1400 for the first time a couple of days ago. Tho it's a little larger than recommended for my 1610D & the soil here is black gumbo, all went well. The tiller did a good job & the tractor didn't protest as long as I didn't try to take too deep a bite.
    However; the tiller is missing the side tine guards or skirts and leaves a high ridge of soil on both sides of the tiller. Made for a lot of extra work finishing off the rows. (I like to leave untilled strips between my rows for walking/working.)
    If any of you could post a pic of your guard/skirt--- (maybe while taking pic's for the show off your tiller thread,)-- & the general dimensions for it. I would greatly appreciate it. Seems like they should be pretty easy to fabricate & would make for a cleaner till.
    Thanks Bob.
  2. #2
    Elite Member
    Join Date
    Dec 2009
    gilmer tx
    Bobcat CT235
    Default Re: RS1400 guards/skirts. Need to fabricate a pair
    This is an RS1300, don't know whether guards would be same as yours or not. 15-1/4" long point to long point, 11-1/2" short point to short point, holes and slots 7/16", 2 end holes 4-3/4" cc, middle hole 8-1/4" from left to center, 7" from right to center, If you run a straight edge thru the middle of the center hole the top of the top slot and bottom of the bottom slot will be centered on the straight edge. There is a radius to the slots, don't know what it is. Slots are 2-3/4" long and start 1/2" from edge. The slots are re-enforced on the back side with appx 1/8" metal strip. Guard is appx 1/16" metal but has formed perimiter to add strength. I think 1/8" metal would be plenty strong. Hope this helps.
    Attached Thumbnails Attached Thumbnails RS1400 guards/skirts. Need to fabricate a pair-100_2154-jpg   RS1400 guards/skirts. Need to fabricate a pair-100_2155-jpg
  3. #3
    Gold Member rmully's Avatar
    Join Date
    Sep 2007
    North Carolina
    YM 2020
    I would make a template and have the pair cut out of 3/16 steel...that way they will last
Similar Threads
  1. looking for a pair of vintage style snow tires for my truck
    By botamike in forum Trailers & Transportation
    Last Post: 10-26-2009, 12:24 PM
  2. Tires Need help locating another pair of these rice patty ag tires
    By botamike in forum Owning/Operating
    Last Post: 10-06-2009, 09:10 PM
  3. Spring Tension Bars for RS1400 Tiller
    By Eddie in forum Yanmar
    Last Post: 09-13-2006, 06:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
