oldgrayfellow
Member
- Joined
- Feb 19, 2010
- Messages
- 35
Tried out my used RS1200 tiller for the first time today, on my YM 186D. Had been tilling my 50 foot garden (soft, sandy loam, no rocks, a few minor roots) for 3 passes, stopping the tiller at the end of each pass.
At the end of the 3rd pass, i raised the tiller, stopped, and clutched to disengage the PTO, to find that it would not disengage. There was no neutral-- i could shift the PTO to high or low speed, but neutral position seemed to have disappeared.
After 5-6 attempts to find neutral i shut off the tractor and took a look at the back, to find milky green fluid running out of the rear end around the PTO shaft. In removing the tiller PTO coupling, i found that the PTO shaft coming out of the tractor had apparently broken loose internally, and could be flopped around from side-to-side by hand.
OK, what the heck happened and why?
And then, what do i do to fix it? I have the service manual, and am willing to tear into it, but it would help a bunch if somebody could tell me the most likely problem and the best way to go about it.
Thanks loads.
Thanks loads.
