Draft Control Adjustment
   / Draft Control Adjustment #1
edmartin
SC, USA
Yanmar YM2000
I have a YM2000 and would like to properly setup and adjust the draft control. I've looked in my owners and service manuals and find very little. Any help would be greatly appreciated. Thanks.
   / Draft Control Adjustment #2
Draft controls have always been mysterious to me. I have read considerable about them but confess I don't fully understand them. I had an old Ford Jubilee with draft control, never figured out how to usefully use it. Have read several posts on different forums about the Yanmar draft controls. Seems they were mainly for use with rice tillers. Also seems they operated off either a cable or rod that moved as the tiller moved which in turn operated the control mechanism on the tractor causing it to go up or down. My 2002d has a draft control handle which I only use to slow down drop speed on the 3 point. There is linkage under the seat area that ends up with a pin out on the end that was intended for something to hook up too. If I manually move that pin the lift will move. Don't know if the 2000 has that or not. Haven't really said anything to help but don't think I've hurt you either. I'll be interested to hear others knowledge on this subject.
   / Draft Control Adjustment #3
On a Ym 2000 which I have also Up or Down is set by how far or which way you move the handle there is a knob that you screw into the slide/Gap were you lock it is where your handle stops so it won't move lower or higher than that point. ;) and the screw with the pin on mine just bleeds off the valve to let the lift fall in hence Counter clock wise the further back you turn it the lift falls easier/faster mover it forward is higher it the lift goes. After I serviced my fluid and had to replace my ghetto rigged pickup screen it sets perfect straight up.look hard you can see it on the left side of the valve.
I'm rained in :laughing:
Carey
   / Draft Control Adjustment #4
On my 1500D it is the same as yours, Carey. But there is a lever with a tab under the left seat support. The lever is pulled out and slid forward to engage a different hole that allows draft of the lift. It is pressure sensative. Where you leave the lift lever to the height of your attachment, the control valve will sense the pressure on the small shaft (where the spring is located in Carey's pic) and maintain the pressure to keep the implement at the optimal hydraulic pressure. It does not mean that it will maintain the same depth. I got this out of the manual. I have used it for setting the tater plow and digging trenches. The little lever with the rubber tube over it slows or hastens the lift to drop. Of course, I could be way out in left field.
   / Draft Control Adjustment #5
The Ym2000 does not have draft control. Exactly what are you trying to do?
   / Draft Control Adjustment #6
Again, I am unfamiliar with the ym2000. If you have draft control you should have the 2nd lever right to the left (sitting in the seat) of the lift handle, if not you probably don't have draft control. Draft handle is down in the picture on the 2002d.
   / Draft Control Adjustment #7
That second control lever one typ associates with a draft control doesn't function as a normal draft control which attempts to control implement depth by sensing change in force exerted on the 3pt links.
On the Yanmar's I'm familiar with, this control attempts to do the same thing in a different way and only for yanmar tillers set up to work with the UFO controls. There is a arm near the upper 3pt arms and it is linked to the tiller's drag via cable and some linkage. The draft attemps to control the tiller depth by associating the angle of the drag with tiller depth.
From several others that are much more in the know than I am, I've been told I'm the only one they know of that has ever hooked up the UFO controls to control tiller depth and side-side angle of the tiller.
See pics. 1st shows the arm associated with the draft control. There is a cable attached which runs back to the tiller. From there, pic 2, there is some linkage to the drag.
When connected, I can manually lift/lower the drag by hand and the 3pt reacts by either lifting or lowering the 3pt arms.
   / Draft Control Adjustment #8
ain't no draft control on a 2000
   / Draft Control Adjustment #9
I bet the OP knows Now What not to call his 3PT.Lift :laughing: I even learned something new on how the Draft is set up like on a Yanmar.:D
Carey
   / Draft Control Adjustment #10
Hang in there Normde! I'm on your side. Mickey, excellent pictures explaining the Yanmar draft control. My 2002d place to hook the cable up is on the right side. I've no intention of hooking it up but you have helped me confirm what it is.
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
BOX OF SCHUMACHER 6A BATTERY CHARGERS (A51248)
BOX OF SCHUMACHER...
