Results 1 to 6 of 6
  1. #1
    Member
    Join Date
    Apr 2010
    Posts
    25
    Default Ym186 1510. What size attachments will it pull? Box blade, soil pulverizor
    2wd ym186 with turf tires.
    Other than 4' blades will the tractor be able to pull/use a 5' blade/scrape. Don't find many 4' attachements to rent or buy used. Only need to move small amounts of dirt and smooth out the top soil in a old pasture which is now my back yard.
    I plan on adding a bumper to the front end that can hold gym weights. And I could add some water to he tires.
  2. #2
    Elite Member
    Join Date
    Mar 2002
    Posts
    4,016
    Default Re: Ym186 1510. What size attachments will it pull? Box blade, soil pulverizor
    It might, but you won't like it. Get a 4' or less. People dump their 5 footers because they are too big.
  3. #3
    Super Star Member California's Avatar
    Join Date
    Jan 2004
    Posts
    10,099
    Sonoma County
    Yanmar YM240, and now just one YM186D
    My YM186D (4x4, ag tires) came with an old 5 ft blade. The previous owner suggested sell the blade because it did nothing but halt the tractor. ... and I think he used it mostly to clear snow.
    My experience was that hitting a patch of turf roots is enough to turn that blade into a boat anchor. Maybe iron weights in the rear wheels would help - water wasn't enough.
    Also the YM186 (D) lift is too energetic to make subtle adjustments. I could adjust the drop valve to go down slowly, but lifting the blade when it dug too hard was sudden and extreme with no way to feather it.
    I researched that blade and saw one owner had added 'trainer wheels' on the back to limit how much it could dig. I may do the same.
    Photo - blade.
    However a 4 ft rotary mower works ok after 240 lbs of front bumper weights.
  4. #4
    Member
    Join Date
    Apr 2010
    Posts
    25
    I am running a 4' rhino rotary cutter without weights. Does ok on level ground or down hill. Up hill or across uneven sections the lack of front end weight is readly noticed with total lack of steering.
    So the search for a 4' blade is on. Though a 5' blade with some torch work could equal 4'?..?...
  5. #5
    Elite Member
    Join Date
    Mar 2002
    Posts
    4,016
    Quote Originally Posted by renter damaged uhoh View Post
    It depends on whether you are talking box blade or scraper blade, huge difference. You can use a 5' scrape blade, no prob. Hit roots with any blade and the front end is coming up, no matter what size. Just be ready to stab the clutch at all times. Suitcase weights on the front help a lot.
  6. #6
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,382
    NW Oregon
    Deere 317 & L118
    you can pull the 4 footer with a full load of dirt but a 5 footer wont be able to move with a full load. Also, when i use my boxblade, it occasionally will get packed full of dirt and when you lift it up you will pop a wheelie or it wont lift it at all. Also, watch for roots when you are digging. The picture shows what happens but since all the power is put onto the back wheels and since they are slipping so much, it can be a very rough ride. with the R3 turf tires on your tractor, i'd look at adding weight to your rear tires and possibly even chains for extra traction. A 4 foot boxblade will pull a little less than a 5 footer but it will be more efficient since your tractor will have a better match size wise and will be more productive since you will be able to work faster. I can fill my 4 foot boxblade to where the dirt is falling out the back in 2wd on level ground.
    Attached Thumbnails Attached Thumbnails Ym186 1510. What size attachments will it pull? Box blade, soil pulverizor-4-25-10-023-jpg   Ym186 1510. What size attachments will it pull? Box blade, soil pulverizor-5-15-10-041-jpg
    My Fleet:
    2004 Bobcat 430G Excavator
    2006 Bobcat T140 Compact Track Loader
Similar Threads
  1. Box Scraper Beginners guide to using a box blade
    By canoetrpr in forum Attachments
    Last Post: 08-07-2017, 05:17 PM
  2. box blade vs standard blade
    By jkaz in forum Attachments
    Last Post: 08-14-2010, 10:12 AM
  3. Box Scraper Box Blade Size for Kubota B7500
    By Old Blevins in forum Attachments
    Last Post: 01-15-2010, 02:34 PM
  4. Box Scraper Box Scraper with Hinged Rear Blade
    By aquetrac in forum Attachments
    Last Post: 04-06-2008, 05:28 PM
  5. Tractor Sizing Blade Box size for a YM 2210D
    By souperbee in forum Yanmar
    Last Post: 05-24-2007, 04:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
