Hello gentlemen and ladies if any present, I am new to this forum, ( have been following all the post for about a month now ) and I bought (traded) an 1510 D about 2 months ago and I could not be happier. I traded an international 404 for it and it was the best trade I ever made. This little tractor has more power than I would have ever figured.
With all of that out of the way I have some rather simple qeustions, so I will number them as follows:
1: Right between my legs there is a twist valve for adjusting the hydroulic flow, what exactly does it adjust? and what are the adjustments. I.E. all the way out does what, all the way in does what etc.
2: on the right side ( when sitting on it ) there is another one of these valves, down on the side of the frame ulmost directly down from the leading edge of the seat. I beleive this controls the 3 point but could use some quidence on what it is for and how one wishes to adjust it.
3: Under the seat at the very back and on top there is a removeable screw plastic plug. I am assumeing this is where one wants to add hydroulic fluid? If not please clairify for me as to where all these things are at, as I am at this time unable to read Japanese. ( if this is for fluid, how full should it be).
4: This tractor has the shuttle shift ( shift gears without using clutch ) I assumeing it works off of the hydroulic system, what grade of fluid does one want to use with this tractor.
5: Does anyone have a john deer part number for oil filter or a mobile 1 number?
Thanks for any input in advance, and in the near future I will be looking for mannuals etc.
