Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
  1. #1
    Member thallman's Avatar
    Join Date
    Mar 2011
    Posts
    44
    Mahindra 7060 4WD
    Default PBY Power Beyond & Detent Valve question
    Hey, newbie here. I have a (hopefully) quick question.
    Tractor: Yanmar 336
    Application: Log splitter
    Tapping into divider block to set up rear remote hydraulics.
    Manual calls for a auxiliary valve with five ports: IN, OUT, A, B, PBY.
    I have the schematics.
    Therefore, Does PBY stand for power beyond?
    Also, has anyone found a single spool valve with a PBY and a pressure detent?
    I want to press the lever backwards to detent untill the cyclinder is completely retracted so I don't have to hold it.
    Part numbers would be great. So far, after talking with Surplus Center, the fellow said he didn't know of a single spool power beyond valve with a pressure detent. I know they must exist! What are you fellows using in this situation?
    THANKS!
    -Thomas
  2. #2
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    Kioti DK45SE hst cab
    Default Re: PBY Power Beyond & Detent Valve question
    i have a single spool with detente like you want. got it at surplus center about 5 years ago.
    did you tell them its for a log splitter?
    they called mine a log splitter valve
    mines hooked up to a 1996 John Deere 870 (Yanmar). To get power beyond, i had to add JD's power beyond kit which entailed splitting the hydraulics at the mounting block under the tractor and adding the new kit in front of the old one. Hard to describe but easy to do. kit had full instructions. took about 30 minutes. removing the seat took the longest. No tube cutting was involved. just replaced old bolts with newer longer bolts to hold thing together.
    then theres a hose loop on the power beyond kit. simply unhook hose, install hoses to log splitter, done.
    when finished with splitter, replace looped hose, back to original operation.
    I added an additional 2 spool non detente valve on the right rear fender that hooks into the power beyond. this allows for my chute deflector on the snowblower.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  3. #3
    Join Date
    Mar 2011
    Posts
    44
    Mahindra 7060 4WD
    Thanks, unfortuently, I ordered this valve yesterday because it said "open-center" but it apparently won't work because it doesn't have a "PBY" port -- or maybe it will and I'm just ignorant of how to make it work. Anyways, like I said earlier I need a five port valve (PBY) with a detent--don't want to hold the lever to retract the hydraulic wood splitter cyclinder.
    If I can't use this valve and someone else can let me know I paid $110 + $14 shipping for it. Northern Tool wants me to pay return shipping + a 15% restocking fee! That stinks!
    I would of course, be willing to trade for a valve as described above or that would work in my situation.
    Anyone out there with more thoughts on this?
  4. #4
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    this is the spool i used
    https://www.surpluscenter.com/item.a...name=hydraulic
    i have it on my splitter and it has worked fine. it has detent for raising the cyllinder.
    it just allows the hyd fluid to pass tight on thru it until i move the lever, then it bypasses the fluid to my cyllinder. its for double acting cyllinder, and its $70.00
    im not too sure what you bean by the 5th port saying PBY??
    the valve doewsnt need a power beyond port. its a open center valve, so the fluid just passes thru unless you move the handle. are you sure this isnt supposed to be the pressure release adjustment??? for the detent
    Attached Thumbnails Attached Thumbnails PBY Power Beyond & Detent Valve question-splitter-3-jpg
    currently own
  5. #5
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    also, here are some kind of crummy camera phone pics of my power beyond system. im sure your yanmar is similar
    Attached Thumbnails Attached Thumbnails PBY Power Beyond & Detent Valve question-0308111550-jpg   PBY Power Beyond & Detent Valve question-0308111550a-jpg   PBY Power Beyond & Detent Valve question-0308111551-jpg
    currently own
  6. #6
    Join Date
    Mar 2011
    Posts
    44
    Mahindra 7060 4WD
    This is the reason why I "need" a PBY port. So says the service manual.
    PBY Power Beyond & Detent Valve question-yanmar336_hyd2-gif
  7. #7
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    try this link....this splitting block may not be the control valves you think .
    http://www.mytractorforum.com/showthread.php?t=90222
    hope this helps
    currently own
  8. #8
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    currently own
  9. #9
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    and another link
    apparently the yanmar is different than most other tractors
    Need hydraulic help - Net Tractor Talk
    currently own
  10. #10
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    currently own
Similar Threads
  1. Replies: 7
    Last Post: 12-29-2010, 05:24 PM
  2. Power Beyond or HPCO valve help needed
    By bbutcher in forum Hydraulics
    Last Post: 12-27-2010, 09:54 AM
  3. Replies: 26
    Last Post: 06-04-2009, 06:51 AM
  4. Hydraulic valve for grapple... what one?
    By 2310 guy in forum Hydraulics
    Last Post: 06-26-2007, 05:18 PM
  5. Hydraulic Tip 'N Tilt - OK, Top 'N Tilt
    By Bird in forum Kubota Owning/Operating
    Last Post: 05-02-2001, 01:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
