Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Oct 2010
    Posts
    11
    Alabama
    Kubota L2800
    Default the back flap on yanmar tiller and top link
    I just got a RS1400 tiller haven't use it yet. It don't have the back flap, so do i really need the back flap. If I do where can I buy one from. Also when I raise it up all the way it hit the back tire. I have heard of a special top link bracket. Do anybody have the measurement of that piece. So I could get one make.
  2. #2
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,409
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Default Re: the back flap on yanmar tiller and top link
    Quote Originally Posted by Smooth View Post
    My RS1200 back flap was a shredded mess, so I trimmed it a little. The flap is there to smooth out the tilled soil after the tiller digs it up.
    the back flap on yanmar tiller and top link-dscf0210-small-jpg
    I had to use the 35" long lower lift arms off my Massey Ferguson 135 tractor since the 25" arms on my kubota B7510HST caused the wheel rubbing problem you have. I also installed a slip clutch on the pto shaft and had to add a pto extender on the tiller to keep the slip clutch from rubbing on the top sheet metal on the tiller. I bought the shortest pto shaft from TSC and then trimmed it to get everything to fit.
    the back flap on yanmar tiller and top link-dscf0211-small-jpg
  3. #3
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,265
    gilmer tx
    Bobcat CT235
    Don't know where you are located. LCI Products in Wills Point Tx used to have a pretty good pile of Yanmar tillers. They sold parts off some of them. Haven't been by there in a while so not sure they are still there. I believe the in the Northwest Erinies Imports may have them. In the Southeast Fredericks may have them. And I'm sure there are other places. I just made a short top link for my tiller and have been using it for several years. Mine is an RS1200.
    Attached Thumbnails Attached Thumbnails the back flap on yanmar tiller and top link-100_0954-jpg   the back flap on yanmar tiller and top link-100_2150-jpg
  4. #4
    Veteran Member Mickey_Fx's Avatar
    Join Date
    Aug 2005
    Posts
    1,132
    Vancouver Wa.
    Yanmar Fx24D, Cub 3204
    Yanmar has their tiller close coupled and if a factory type upper link isn't used, you will likely hit the rear tires with the tiller.
    Look closely at the pic and you can see the upper link and how short the bar is. It attaches to a special upper link extension and when all connected, when the tiller is in the up position the bar is almost vert. The extension piece comes in various models to fit different tractor models. The special upper link is designed so as the tiller is lifted or lowered it pivots about the lower link mounts.
    Depending upon tiller and tractor model the rear flap is used in conjunction with the UFO controls to automatically control the tiller depth.
    As Winston mentions, Ernie is a good place to check as he usually has spares of a lot of parts. Ernie is also one of the GOOD GUYS in the Yanmar market.
    Attached Thumbnails Attached Thumbnails the back flap on yanmar tiller and top link-top-link-jpg
    Yanmar Fx24D,
    Koyker 155 loader,
    RSB-1300 tiller
    Cub 3204, 48" mower
    Bolen 1257 GT with tiller
  5. #5
    Member
    Join Date
    Jun 2011
    Posts
    46
    yanmar ym1500
    What is the difference in the rs1200 and the rs1400 tillers?
  6. #6
    Super Star Member California's Avatar
    Join Date
    Jan 2004
    Posts
    10,110
    Sonoma County
    Yanmar YM240, and now just one YM186D
    1200/1400mm width?
  7. #7
    Veteran Member MJPetersen's Avatar
    Join Date
    Feb 2007
    Posts
    1,255
    Warsaw, Poland
    YM 1510-D
    I believe that the 1400 is also gear drive and the 1200 is chain drive--I am not an expert in these things but that is what I think.
    it may also be that the 1400 is 3pt and the 1200 is a 2pt hook up--again that may not be universally true.
    Mike
    "In all your ways acknowledge Him and He will direct your paths." Solomon
    YM1510D, YM 1202 tiller, The following home made tools: Quick Hitch, KK copy dirt scoop, imitation Gannon rollover box blade, Forks on 3pt, a Rear Blade with gauge wheels and a 1.5 yd dump trailer.
  8. #8
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,265
    gilmer tx
    Bobcat CT235
    I am curious as just what designates chain or gear drive. My RS1300 is a gear drive.
  9. #9
    Join Date
    Jan 2004
    Posts
    10,110
    Sonoma County
    My RS1400 is a gear drive.
  10. #10
    Gold Member rmully's Avatar
    Join Date
    Sep 2007
    Posts
    449
    North Carolina
    YM 2020
    When I bought my 1400 there was no rear flap. I ended up making one out of 3/16 steel plate and attached 2 chains to the flap and attached the other end of the chain to the cross bar that used to work the wheels. The sheet is flat and does a great job of smoothing the tilled soil, I think the extra weight helps.
    Experience is what you have left after you have lost everything.
Similar Threads
  1. 3038e - New Top Link
    By nunyabinis in forum John Deere Owning/Operating
    Last Post: 09-11-2011, 03:20 PM
  2. Dirt Moving Yanmar RS1200 tiller sheetmetal vibrated off
    By pokey54 in forum Yanmar
    Last Post: 09-14-2010, 06:56 PM
  3. Introductions and 3pt Tiller Reality Check
    By apmonte in forum Rototillers
    Last Post: 01-16-2009, 09:43 AM
  4. Tiller How high should my top link be mounted to my tiller?
    By Randybee1 in forum Attachments
    Last Post: 02-01-2008, 05:20 AM
  5. Yanmar RS1400 tiller - Working rpm?
    By California in forum Yanmar
    Last Post: 11-14-2007, 02:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
