1810D - my first tractor
   / 1810D - my first tractor #1
Teigrek
Lower Silesia (Poland)
Yanmar YM1810D
Hi everyone:)
I'm new to this forum. I live in the Sudety Mountains, in Lower Silesia in Poland.
A week ago I bought a tractor - Yanmar YM1810D. This is my first tractor and I have some questions about its construction. For starters - the clutch: I now replace the clutch and in the clutch housing I saw the other lever, below clutch lever . This lever is jointly controlled clutch-pedal - what is the mechanism?
Michał
   / 1810D - my first tractor #2
Looks like something to do with powershift?
   / 1810D - my first tractor #3
It is called the inertia brake. I have an adjustment procedure for a Ym226 which is probably like your 1810d but that is a guess.
Thanks for the information.
How does the inertia brake ? Can you write the adjustment procedure?
   / 1810D - my first tractor #5
Here is a try. That is about as clear as the pictures are in my manual. Other than the picture (ref D) there is not anymore information about the inertia brake. Hope this helps.
Winston thank you for the scans:) Now I know how to properly adjust the inertia brake.
But I'm still curious about the function of this mechanism....
   / 1810D - my first tractor #7
Me too. I believe as the name implies, it some way stops rotation on the power shift clutch shaft. :confused:
If anyone has the wiring diagram for my tractor, or similar?
Seems that everything works, but I have a few separated plugins, and I do not know what they are.
   / 1810D - my first tractor #9
Here is my YM2002D out of operators manual. Don't know how close it is to yours.
Thanks. This electrical system is the same as in my tractor.
My clutch sensor was disconnected and the cables from the starter were bridged. Before, I did not know what doing the clutch sensor.
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52748)
2016 Kawasaki 70...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2013 Ford Flex SUV (A50324)
2013 Ford Flex SUV...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2016 Dodge Charger SRT Hellcat Sedan (A50324)
2016 Dodge Charger...
