Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Platinum Member Scotty Dive's Avatar
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    Default Re: Curl Bucket Cylinder over extended on VTEK?
    update - removed the cylinder and the rod pulled right out....You can see where it broke
    Thanks,
    Scotty Dive
    Yanmar YM2020D "Git er Done Too"
    Pictures! http://s139.photobucket.com/albums/q...t=dfc00199.pbw
  2. #12
    Join Date
    Dec 2009
    Posts
    1,833
    gilmer tx
    yanmar 2002d
    Well alrighty, your on the way.
  3. #13
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    I think I am going to order from VN1(little more $$) to assure I get the correct cylinder but I thought I would post up the measurements I took off the one good one I have for posterity:
    Stroke: 11 1/2"
    Cylinder Diameter (not Bore): 1 15/16"
    Rod Diameter: 1"
    Retracted - Center of eye to center of eye: 20 1/8"
    Extended - Center of eye to center of eye: 31 3/4"
    Eye hole: 3/4"
    Looks like Surplus center has a match with a 12" stroke. Part number 9-7270-12.
    Thanks,
    Scotty Dive
  4. #14
    New Member
    Join Date
    Mar 2009
    Posts
    15
    Central Ma.
    B3300su
    I wouldnt even bother with VN.
    Just go to Bailey Hydraulic....Google them for the web address.
    They will have the cylinders..cheaper than the VN.
    Measure with the bucket at the full curl in(center to center) and the the with of the tee ends and then the rod diameter.
    I repaced mine after they were leaking...did the same as you, looked at Northern Tools, also had to contact VN three times before they responded back....only to find out they were the most money.
  5. #15
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    Default
    Do you have the V2 loader? If you replaced the curl cylinders, do you have a part # with bailey?
    Thanks,
    Scotty Dive
  6. #16
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    I have to say....I called VN1 Tractor on Monday, ordered and had shipped same day. Received on Wednesday via Fedex ground. I then brought the new cylinder to a hydraulics shop to see if they could match it up and to get a T so I can add a temporary pressure gauge to test the system.
    They said it looked like a quality cylinder but custom made due to the size of the end cap welded on and zerk fittings already installed...for what that is worth. In any event - they remeasured the rod and case and its a metric cylinder (no surprise there - OD of the cylinder is 50mm and the rod is 25mm. the pin is 3/4". Hope that helps if anyone else needs the info.
    Thanks,
    Scotty Dive
  7. #17
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    I posted this over in the Hydraulics section as well....but any idea why when I installed a pressure guage into the system that I received a ~2100 psi reading with the curl bcuket all the way down and only 600 psi max when all the way up?
    Thanks,
    Scotty Dive
  8. #18
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    2,980
    Kansas
    YM3810D Yanmar
    Quote Originally Posted by Scotty Dive View Post
    I wonder if there is an adjustment on the curl spool valve to either set the center or the over travel is all I can think, it is a 1 stick yes and not 2?
    The other thing that comes to mind visually is the gage is in the extend port so maybe there is something in that end of the cyl that hasn't sealed yet or maybe putting the gage in the pressure "in" port on the joystick control would give better measurements?
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  9. #19
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    In a stroke of genius caused by my own stupidity....I started thinking....that shouldn't I measure the pressure on both sides of the cylinder????
    When I moved the guage to the other cylinder port...whammo - 2100 psi. the 600 psi must be the back presssure the cylinder see's when on the return side.
    Thanks,
    Scotty Dive
  10. #20
    Join Date
    Dec 2009
    Posts
    1,833
    gilmer tx
    yanmar 2002d
    I don't understand why you would have 600# back pressure unless the 3 point is someway loaded. If your 3 point is unloaded your back pressure should be close to zilch, nada. Maybe a few pounds, but not much.
Similar Threads
  1. Cushioning a bucket cylinder
    By 638 in forum Hydraulics
    Last Post: 08-23-2011, 05:29 PM
  2. Bucket Cylinder extension?
    By moojamboo in forum Hydraulics
    Last Post: 06-13-2011, 08:47 PM
  3. Prince LV series valves
    By samohn in forum Hydraulics
    Last Post: 07-07-2009, 09:33 AM
  4. LA680 Loader bucket won't curl back
    By Steve Wyatt in forum Kubota Owning/Operating
    Last Post: 06-29-2009, 09:23 AM
  5. Hydraulic Question
    By butzkeg in forum John Deere Owning/Operating
    Last Post: 12-11-2001, 07:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
