Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Member
    Join Date
    Jan 2011
    Posts
    25
    yanmar 336D
    Default Re: Engine Piston Height
    I appreciate the come back on that. I' m thinking of have the tops of my piston
    taken done to height of the top of the liners.
  2. #12
    Join Date
    Jun 2010
    Posts
    1,463
    Southern California
    International Harvester 284, Yanmar 1401D, Yanmar 240...etc
    Do you think the resized rods are causing the pistons to protrude too far? I'm surprised there isn't a specification somewhere for this dimension.
  3. #13
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Quote Originally Posted by dalehowe View Post
    What you must be joking???? I cant begin to explain how many ways that is wrong seriously wrong.
    Here is a pic of my engine when I had it down sorry I didn't measure the actual piston height for posterity and it doesn't show a side view.
    I knew it had to be ok because it ran fine up till the HG blew which was the engine builders (hack) mistake of not checking or letting it slide the fact the head was out .009".
    It is common btw for diesels to have pistons above the deck/liners that is how you get 20+ to 1 compression.
    I had to turn the crank so the pistons were down to measure my liner heights (that what I am doing in the one pic) because the pistons are above the liners like I mentioned .019" sounded ok to me that you say yours are.
    Attached Thumbnails Attached Thumbnails Engine Piston Height-img_1112-jpg   Engine Piston Height-img_1110-jpg
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  4. #14
    Silver Member shawnjvl's Avatar
    Join Date
    May 2010
    Posts
    177
    South Mississippi
    YM2000, JD LA120
    When I had my 2000 apart, I seem to remember the pistons were definitely above the deck.
  5. #15
    Join Date
    Jan 2012
    Posts
    1,113
    YM2000
    [QUOTE=Car Doc;2800610]
    It's the Rings and how close they are coming out of the Cyl. is what I would be concerned about the most and or if the Head has been Milled. A machined head ground to much is what usually causes a piston it to hit a valve. and If there was a problem with the Cyl. being to high with the Ultra close Tolerances I seriously doubt the Head would Torque or Seat properly.
  6. #16
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    We have to keep valve timing in mind these diesels have pretty lazy valve timing and dont need very aggressive cams to run right and to be able to make the high compression they do and have to have to live.
    The 4 cycle diesel operates different than 4 cycle gas and as such doesn't need a bunch of added valve timing to get a complete burn/full cylinder at higher speeds gas engines run at.
    The possibility of a valve hitting a piston is slim to none still after .010-.020 is taken off imho just because the valves are not open anywhere near TDC.
    My experience with Yanmar is limited to my tractor but his 336 is basically the same and my valves were below the head deck by a fair amount and after grinding valves and seats its even further under the deck. So thats why I believe they will never touch, if they were above the head deck which I doubt they are the story may be different. fwtw (my pre-chambers were above the deck by a good bit and Id say better than .020 just for conversation they never hit before or after milling and is the main reason I added an extra copper seal ring)
    Consider our compression releases for instance...they hold the exhaust valve open all the way thru the cycle granted you could possibly adjust them enough so they hit but you take the cam out of the equation and hold them open is what I am getting at there.
    And dont get me wrong I dont have facts to back that up just my gut feelings knowing engine manufacturers as well as I do.
  7. #17
    Elite Member
    Join Date
    Mar 2010
    Posts
    2,631
    Ontario
    CT235
    Minimum quench distance on a high performance automotive gas engine is 35 to 40 thou. Factory tolerance is usually between 60 and 100 thou., but with stricter emissions and higher compression ratios this number is closer to the 35 number.
    These little diesels run much tighter than that because of the limited rpm they see and the small bore. Personally I would go no tighter than 20 thou.
    You can absolutely have the pistons tops milled, if you determine you do not have enough clearance. It's done all the time. It is up to you to take the proper measurements though, and use the compressed thickness of your head gasket for your calculations.
    If it's strictly for the prechamber interference, you can clearance the piston with a dremel and a steady hand. You're only taking the equivalent of the amount of head milling that was done, which is easily achieved.
    As to the question about the rod reconditioning changing the piston height, If the job is done correctly the center to center dimension of the rod does not change. Therefor the quench distance should remain the same.
    Tim.
Similar Threads
  1. Oil & Fuel TY290 engine / 2i70 fuel injection pump
    By kingjames8283 in forum Chinese Tractors
    Last Post: 02-23-2016, 03:56 PM
  2. Engine changes to Diesel x7xx series.
    By JDTank in forum John Deere Lawn & Garden
    Last Post: 03-11-2012, 08:21 AM
  3. L110 sat for 2 years
    By donn12 in forum John Deere Lawn & Garden
    Last Post: 10-17-2011, 10:31 PM
  4. Hows this for new oil discussion
    By neucam in forum Oil, Fuel & Lubricants
    Last Post: 12-12-2008, 11:51 PM
  5. Is it just me, or does this go too far?
    By MessickFarmEqu in forum John Deere Buying/Pricing
    Last Post: 12-10-2008, 10:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
