Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    New Member
    Join Date
    Aug 2011
    Posts
    11
    JD L120
    Default Re: YM3000-Bad ignition switch ?
    Just got my new switch in from Hoye. Only problem is it's completely different from the old switch. Won't even fit in the hole that the old switch came out of. No prob, I can do some filing and grinding and make it fit. The big problem is figuring out which wire goes where. I've got 2 of the 5 wires figured out. Got to trace which one of the 3 remaining go to the starter. The last 2 go to the glow plugs and I think are interchangeable. I think. I hope.
    Also the little compartment where the switch and all the wiring lives is right behind the fuel tank and there's about 40 years of accumulated diesel spillage mixed with grime and leaves and pine straw. Also a rat had made a nice nest out of 2 huge balls of twine at some point in time. I'm having fun now !!
  2. #12
    Elite Member California's Avatar
    Join Date
    Jan 2004
    Posts
    4,912
    Sonoma County
    Yanmar YM240 and YM186D
    Don't make the dumb mistake I did back when I got the YM240. Mud was caked everywhere including a solid brick under the voltage regulator. So I hit it with the pressure washer.
    Big mistake - next time I ran it, it smoked both the regulator and alternator.
  3. #13
    Platinum Member NHmitch's Avatar
    Join Date
    Mar 2012
    Posts
    767
    SW New Hampshire
    Bolens G154/IsekiTX1300F
    You could just buy a cheap push button starter switch at a local auto store, if you are not worried about someone driving it off. Usually they are under $10. A tractor ignition key really does not offer you much protection, because a lot of times you can just put in a screwdriver, and start the tractor, or reach under, and hot wire it. I would go with the push button, unless you have kids that you are worried about starting the tractor when you are not around.
    Mitch
  4. #14
    Veteran Member deepNdirt's Avatar
    Join Date
    Sep 2009
    Posts
    1,926
    Nth East Ga, USA
    yanmar YM-1700
    I'm just curious if the switch had been starting the tractor up to this point and the only problem is the key doesn't turn the switch, Why not order a new Key first? perhaps the old has been worn out,
    as had been mentioned the ign. switch can easily be turned, even with an alternative key, I have made a couple of spare keys from old toyota truck keys I've had laying around using the original key as a template cutting the toyota key down to the approx length and file/form the teeth, a few trial fits & files and they work, But on the other hand if the ign. switch has locked up inside you may could have taken it to a locksmith and had them shoot it with graphite to try and free up for you,
    we should modify the old saying that goes " if its not broken don't try to fix it" -----> to a new saying "if its not really broken don't replace it" because chances are the replacement isn't an OEM but a Generic replacement, thus now having to modify the tractor to make it work,
  5. #15
    Gold Member
    Join Date
    Nov 2004
    Posts
    303
    Nevada
    John Deere 950 and 970
    Wonder if you got the right part?? The one they sent to replace my key switch was a direct replacement. Terminals were exactly the same, marked the same, even the same key fit the lock. Might want to call and ask just to be sure. I just transfered the wires, one terminal at a time to the new switch, no guessing where anything went, worked perfectly. Safety, be sure and disconnect the ground wire from the battery before doing the change or even removing the old switch. I remember getting a nice burn arcing my watch to one of the hot terminals. Just remove the bolt where the wire bolts to the engine on the front right side of the engine.
    Chris
  6. #16
    Join Date
    Jan 2004
    Posts
    4,912
    Sonoma County
    Quote Originally Posted by chriswheeler View Post
    This. Auraaura if the one they sent doesn't fit the hole and the wires don't match up - its not the right part. Send it back and try again.
    The correct part they should have sent is a perfect replica.
  7. #17
    Gold Member
    Approved Advertiser
    Join Date
    Jul 2002
    Posts
    733
    North Texas
    Yanmar
    Your new switch should have looked like this --
    Yanmar Tractor Parts: IGNITION SWITCH - ORIGINAL YANMAR STYLE
    It should be an exact replacement as stated above.
    Do you think that someone may have already mounted a universal type switch in a different spot the dash? Maybe the correct switch hole is empty or has been replaced by a gauge or something? Any way to see a picture of your dash?
    Edit: Is you switch located in the same spot as the attached picture?
    Attached Thumbnails Attached Thumbnails YM3000-Bad ignition switch ?-3000.jpg
    Aaron
    Hoye Tractor Parts
    Contact Us
    (940)592-0181
  8. #18
    New Member
    Join Date
    Aug 2011
    Posts
    11
    JD L120
    OK, pics attached. Old and new switch side by side. Also pic of dash with switch removed. I'm not really thinking someone has already installed a universal switch because the new switch will will absolutely not fit the hole in the dash. If you'll notice on the pic of the dash there is a cutout in the bottom of the hole that matches a protrusion on the original switch. The part of the new switch that fits in the hole in the dash is shaped nothing like this. I could grind some on the new switch and make it fit, and don't really mind doing this as long as it works "electrically". DeepNdirt, you said I could order a new key.....where could I get one? I'll try it for sure. Markings on the back of new and old switch are completely different also.
    Attached Thumbnails Attached Thumbnails YM3000-Bad ignition switch ?-061.jpg   YM3000-Bad ignition switch ?-055.jpg
  9. #19
    Join Date
    Sep 2009
    Posts
    1,926
    Nth East Ga, USA
    yanmar YM-1700
    if I'm not mistaken I have read here on TBN a dealer has or can order the keys we need, if not here is one on-line resource, HOME OF THE EQUIPMENT KEYS - WWW.BEACHSLOCK.COM I think the key you're looking for will be the B-93A
  10. #20
    New Member
    Join Date
    Aug 2011
    Posts
    11
    JD L120
    OK, wired up the new switch like I think it ought to be done. Tractor fired right up, but now I'm worried....if I hooked it up wrong could the glow plugs be "glowing" all the time the tractor was running. I'd just unhook the things if I could figure out where they were. I live in south Mississippi and it rarely gets cold enough here to need them anyway.
Similar Threads
  1. Belarus 400 A ignition switch
    By Bobby R in forum Parts/Repairs
    Last Post: 02-13-2012, 12:10 PM
  2. Ignition Switch Problem
    By darkviper5 in forum Mitsubishi/Satoh
    Last Post: 12-14-2011, 01:44 PM
  3. Satoh 470D Ignition Switch
    By Steve777 in forum Mitsubishi/Satoh
    Last Post: 10-30-2011, 12:01 AM
  4. 1630 Ignition Switch, must leave in 'crank' position' to stay running
    By robertiverson in forum New Holland Owning/Operating
    Last Post: 10-26-2011, 10:36 AM
  5. L 5030 HSTC Bad Saftey Switch
    By tom9961 in forum Kubota Owning/Operating
    Last Post: 08-19-2009, 11:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
