Results 11 to 20 of 27
04-30-2012, 06:06 AM #11
Re: modified exhaust
mines straight up and about facing between 1 & 2 o clock. i never get it in the face but it barely emits anything anyway. only that very faint puff on acceleration. then my YM4 on the other hand, the fumes from that thing nearly knock you out. you can see the "blue haze" out the exhaust
Paul YM1500 & YM14 MkII
04-30-2012, 11:06 AM #12
I think whatever works in your situation is the best way!
We all have different obstacles and requirements nothing wrong with modifying it. Now doing it nice that is where I would be super critical it would have to be pretty and functional and not be in the way later when I do repairs etc etc thats me. Pic 1 looks like a good instal fwtw.
Mine is straight up with a flapper that directs the smoke forward and up and wouldn't work any other way with my requirements at this point in time.
jmho I think a good whiff of ulsd smoke is a good thing occasionally it makes me think cheap efficient horse power.
edit: its the choking dust cloud that seems to find me and stick with me when I am tilling a big garden is what I would like to modify!
Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me.
"Hey you didn't build that."
04-30-2012, 02:09 PM #13
Horizontal forward. It's well tucked into the loader arms where I can't snag it in the orchard.
I turned the YM186D exhaust forward like this too, as soon as I brought it home.
I've had good luck re-using the gasket. I have a new gasket on the shelf that I didn't need for either tractor.
04-30-2012, 02:22 PM #14
I did mine like California, Makes it alot easier to cover up when not in use.
04-30-2012, 04:12 PM #15
Yanmar YM2210, Taylor-way 5' finish mower, Woods 4' rotary mower, boom pole, hayride wagon; upgraded tractor with gas turbine engine plus strap on solid rocket motors for that extra boost of speed... but brakes only work when I'm on the ground.
04-30-2012, 05:27 PM #16
YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
1991 Javalen 17ft w/same year 150 Johnson GT
Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
04-30-2012, 06:13 PM #17
If I was turning mine for some reason it would be forward. I spend too much time in the back hooking stuff up like most probably do.
04-30-2012, 08:49 PM #18
I'm thinking that it would be best toward the front too. I need to go stare at it for a while and decide if I want to do it...
05-01-2012, 11:13 AM #19
05-01-2012, 01:06 PM #20Gold Member
- Join Date
- Jan 2012
- Posts
- 316
- Tractor
- YM2000
Guys think about it
Not much of a choice. If you point it backwards Like I would with a quick hitch your be adding a Tail pipe. Back and no exhaust pipe you "Will be Wiffing it up"
Point it down how long will that Last
Similar Threads
3720 Vertical Exhaust??
By sunnyside360 in forum John Deere Owning/OperatingReplies: 24Last Post: 11-30-2008, 09:53 PM -
3525 Exhaust Conversion
By TexBran3 in forum Mahindra Owning/OperatingReplies: 18Last Post: 04-24-2008, 12:21 AM -
Damage from holes in muffler???
By Mundy in forum Parts/RepairsReplies: 26Last Post: 04-20-2008, 09:41 PM -
Exhaust stack on B3030 with cab
By ficord in forum Kubota Owning/OperatingReplies: 14Last Post: 01-13-2008, 10:10 AM -
JD Verical Exhaust WARNING!
By dirtworksequip in forum John Deere Owning/OperatingReplies: 6Last Post: 10-21-2007, 12:31 AM
