Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,258
    gilmer tx
    Bobcat CT235
    Default muriatic acid radiator clean out
    OK, I know y'all (you guys) think I'm touched by now. I admit I do a lot of things that probably don't need done. That is one of the advantages of being retired and a bit retarded. My heat gage on these East Texas 100 degree days has been running up a tad over the midway point on my gage when pulling my finish mower which is my biggest user. I have flushed my system with over the counter flushes but never been happy with the results. I started goggling different home remedies and after quite a bit of reading I determined I was going to try a muriatic acid cleaning. Muriatic acid can be bought at Lowe's for around $8 a gallon. Normal use is for cleaning or etching cement. There muriatic acid is a 20% solution and is actually hydrochloric acid. It is stout stuff and actually reacts with water and causes heating. I removed my radiator, made wooden plugs to mostly plug the inlet and outlet. Cut 3 short pieces of 1/4" hose, plugged one end with a piece of dowel rod, put the other end on the overflow, drain, and small bypass outlets on the radiator. I stood my radiator up. I mixed 2/3 gallon of water and 1/3 gallon of muriatic acid and poured this mixture into the radiator. I let this stay for appx 10 minutes. I then drained and flushed and flushed and flushed. I then mixed up a good dose of baking soda and filled a gallon jug. I poured this into the radiator and let set for 10 minutes or so and again flushed over and over again.
    I know this is getting long. During the flush process I did get out a bunch of crud. The jury is still out on my success or failure. I have reinstalled, hooked up my finish mower and let it run in the garage at 540 RPM. Reason I state that is because these high lift blades require a good deal of horsepower even without cutting grass. My thermostat opens at the first mark on my gage, the gage never went any higher than that. I know the test won't be complete until I have tested it on a hot day with a load. Whenever that happens I will be back with an honest report.
    I will conclude by saying muriatic acid can be dangerous and I am not recommending this process to the world. Please don't ask what I did with the used acid mix. I disposed of it properly. Might add, the solution can be neutralized with several different products. My radiator may start leaking! Sure hope not.
  2. #2
    Super Member tcreeley's Avatar
    Join Date
    Feb 2011
    Posts
    7,993
    Hudson, Maine
    2003 NH TC30
    Default Re: muriatic acid radiator clean out
    I've used it to take the rust out of a steel motorcycle tank. Did a good job. I used a weaker solution than you did. Great stuff. Battery acid is good for rust too- sulfuric acid.
    NH TC30, 7308 loader, 7' snowbear plow, 5' hiller, 5' tillovator (agrisupply), International Agritech 5' towable Bushhog. dumping carryhall, camo brush trailer, 8 hp Trencherman backhoe, International disk harrow, International single plow, Sears ZTL 7000, 8hp Roto Hoe Shredder'nChipper, CubCadet 524 snow blower, CubCadet rear tine tiller, working forge
  3. #3
    Veteran Member Redbug's Avatar
    Join Date
    Aug 2004
    Posts
    2,033
    Columbia, SC
    Kubota L3830HST
    Radiators are a use I had never thought of. I occasionally use muriatic acid to clean rusty tools and files. It can make an old rusty file look new again and with the rust gone files better.
    I'm interested to see your results.
    Dave
    "If your sport does not put grease, blood, or dirt under your fingernails, then it's just a game!"
  4. #4
    Join Date
    Jun 2012
    Posts
    940
    East Tennessee
    John Deere 4200 w/backhoe, Ford 3000,580 Case backhoe
    Interesting,I hope it holds up.Keep us posted.
  5. #5
    Platinum Member CBW1999's Avatar
    Join Date
    May 2008
    Posts
    857
    Northern Vermont on the 45th parallel
    Kubota 7510, Toro Groundsmaster 217D
    I like this idea and would think about doing it on one of my mowers but- am afraid it might fall apart.......(un) fortunately, that is the only one with any type of restriction in flow.
    I've used muriatic acid over the years to deal with hard water caused crud on different items. Caution is an understatement when it comes to the heat reaction in water. I know someone who had the "great" idea of using it to clean their toilet bowl from hard water/rust staining. They dumped in way too much........bubble bubble toil and trouble- crack went the bowl.
    I thank God everyday for all of the blessings he has given me- especially for the one's I do not recognize or see!
  6. #6
    Elite Member
    Join Date
    Sep 2002
    Posts
    3,058
    Washington
    B7100
    I used it to clean up an old encrusted furnace humidifier made from Bakelite (an old thermoset plastic). It looks like new.
    Nasty stuff, though. Wear rubber gloves, a face mask and long sleeves and never pour water directly into acid.
  7. #7
    Join Date
    Aug 2012
    Posts
    985
    Hartford, SD
    Kubota L3400F
    I believe a solution of vinegar would have had the same results although soak time would need to be a little longer...acid is acid.
  8. #8
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,965
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Pure acetic acid is highly corrosive, more so than hydrochloric acid or sulfuric. Here is an interesting fact: 100% sulfuric acid can be stored in a carbon steel tank but dilute it with water and it will dissolve carbon steel quickly. Weaker solutions are not always less corrosive than pure product. Another acid fact: gold is not affected by nitric acid or hydrochloric acid but mix them together and you have Aqua Regencia and they will readily dissolve gold.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  9. #9
    Join Date
    Jan 2012
    Posts
    1,118
    YM2000
    I new I still had some. Used it for YRS. Found it out back. The bucket with the Orange Lid I found it with "Alot" of people will know what for. Do you see the label and the Vertical Warning. Not in my Radiator LOL.
    Attached Thumbnails Attached Thumbnails muriatic acid radiator clean out-002-jpg
  10. #10
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,728
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Quote Originally Posted by Gary Fowler View Post
    That's true.
    Hydrofluoric acid (HF) is called a weak acid, but can dissolve glass. In the semiconductor
    biz, we used a mix of HF and nitric acid, called pirana etch cuz it bubbled furiously. It had to be held
    in polyethylene containers since it could eat thru pyrex glass.
    Aqua Regia (King's water) had to be stored in waxy containers as it was called the "universal solvent".
    We did not use that, but it was discovered centuries ago.
    I had some good results years ago with copper radiators and HCl soaks. These days with most
    rads using aluminum, you have to be less aggressive with the acid.
Similar Threads
  1. TN 75D radiator clean up
    By ironpen in forum New Holland Owning/Operating
    Last Post: 06-21-2010, 08:49 PM
  2. The acid test
    By smfcpacfp in forum Kubota Owning/Operating
    Last Post: 04-01-2008, 08:15 PM
  3. Acid applicators
    By plumboy in forum Ag Tractors & Machinery
    Last Post: 07-05-2005, 09:10 AM
  4. proprionic acid?
    By ddelawaredale in forum Ag Tractors & Machinery
    Last Post: 05-26-2005, 09:13 AM
  5. Battery acid
    By Horse in forum John Deere Owning/Operating
    Last Post: 09-01-2003, 12:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
