Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    New Member
    Join Date
    Aug 2012
    Posts
    9
    Texas
    Yanmar 2210D
    Default Yanmar and V-Tek Help
    I have searched the forum but can't really find a good answer for a guy who don't know a whole lot about the hydraulics. I have a Yanmar 2210D, with a V-Tek V2 loader. I bought it a couple years ago at Bid Reds in near Fort Worth, TX. The right seal on the joystick keeps blowing out. I don't know which valve this is, the in or out. Any thoughts. I love the tractor other than this part of it.
    The bucket dosen't operate at a normal speed when lifting or unloading, has a lot of drag in it.
    Also is there anywhere I can order a new joystick for the V2 loader? When i was replacing the seals in the valves I broke a bolt (very cheap metal bolt) in the joystick that runs through one of the valves.
    Thanks Guys
    Attached Thumbnails Attached Thumbnails Yanmar and V-Tek  Help-img_4718.jpg   Yanmar and V-Tek  Help-img_4725.jpg
  2. #2
    Platinum Member Scotty Dive's Avatar
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    Default Re: Yanmar and V-Tek Help
    CB,
    I have the same loader but not sure if we have the same joystick valve. Mine is a BLB Model BM-40 - if not, take a look at the valve for manufacturing markings and google is your friend. I have a manual I can send you if its the same...just PM me with your email address. FWIW, this is an Italian made valve and only found a few folks in the US familair with it. I spoke to Beiler Hydraulics who can get parts....but in my case, I am waiting for it to fail so I can replace with a more standard valve that includes Power Beyond and Float. - I don't have either in mine.
    As for blowing a seal - if you follow the plumbing you should be able to figure out what the in and what the out is - plus the manual will help. I installed a gauge onto mine to help me see what my pressure is. thats simple to do and any hydraulics place can get you the tees and the gauge. If you are making too much pressure that could be the cause of the seals blowing.....I am not a hydraulics guy....but the gauge and the manual is the first step I would take.
    Thanks,
    Scotty Dive
    Yanmar YM2020D "Git er Done Too"
    Pictures! http://s139.photobucket.com/albums/q...t=dfc00199.pbw
  3. #3
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    2,982
    Kansas
    YM3810D Yanmar
    I am with Scotty on the check pressures both the pump relief setting AND the joystick relief setting should be the same about 2250 psi. I also would suspect finding a different control may solve a couple issues at the same time if the pressures are found to be set correctly?
    edit: I will put it another way the joystick should be set the same as the pump relief is more to the point. The loader will work at any pressure the settings being "the same as" is the correct way to explain it rather than changing the pump pressure its not as easy to adjust fwtw.
    The power beyond capability is arguably what these YM's need to operate properly with the loaders plumbed in series with the 3pt. (long story there)
    Attached Thumbnails Attached Thumbnails Yanmar and V-Tek  Help-pressure-gage-001-1024x768-.jpg
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  4. #4
    Elite Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    4,591
    The Heart of Dixie
    yanmar 3110D
    if it turns out to be the loader valve. Try here Surplus Center - About Us They are an advertiser on this site. I purchased my grapple valve from them
    Yanmar 3110D
    07 Dodge 2500 5.9 Cummins
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    North Star 4 K PSI pressure washer
    Yamaha Timber wolf
    Liquid Logic Coupe Kayak
    16' Towmaster Dump Trailer
    20' Yanmar Hauler
  5. #5
    New Member
    Join Date
    Aug 2012
    Posts
    9
    Texas
    Yanmar 2210D
    Well I called Big Reds in Ennis TX, where i bought the tractor, they said yeah it is probably the joy stick assembly. $350 later the seal still blows. I'm frustrated to say the leaste. I can hear the loader under pressure when i have just the slitest load in it. I am assuming the pressure to the valve control is to high. The bucket lets down at a decent speed but when i try to pick it up or tilt it, it is extremely slow. WTF
  6. #6
    Join Date
    Jun 2010
    Posts
    1,263
    Southern California
    International Harvester 284, Yanmar 1401D, Yanmar 240
    How is the tractor's hydraulic system plumbed? Does the hydraulic line from the pump go to the loader valve, then the rear lift in series? Does your rear lift leak down faster than it should?
  7. #7
    New Member
    Join Date
    Aug 2012
    Posts
    9
    Texas
    Yanmar 2210D
    The hydro system is in one series. The back box blade does seem to leak down faster than it should.
  8. #8
    Join Date
    Feb 2005
    Posts
    4,591
    The Heart of Dixie
    yanmar 3110D
    Quote Originally Posted by charlie brown View Post
    The hydro system is in one series. .
    That could be your problem.It doesn't need to be plumbed in series.
    Yanmar 3110D
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    Yamaha Timber wolf
    20' Yanmar Hauler
  9. #9
    Gold Member
    Join Date
    Mar 2011
    Posts
    286
    Ford 1720 SSS 4x4
    I would check the return line for excessive back pressure. The return line may be restricted or too small.
    Check the plumbing, is the pump output going into proper port (inlet) if it was plumbed into the outlet that would work but blow the seals out.
    90cummins
  10. #10
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Also check your pressure relief in that joystick. If it is like the one on my Yanmar with the V3 loader, the only relief in that system is on the joystick control. I sold my tractor to my brother in law and after a few months the hydraulic pump would start leaking when he used the FEL. He finally got the bolts tight enough to stop any leaks and the pump housing blew up. The relief valve had froze up or something and the way they plumbed up the hydraulics, when you pull the FEL lever, it shuts all the pressure to the FEL and somehow it was deadheading and the pump is gear drive so it pumps till the motor stalls or pump blows up. New pump was $500 and change from Howe tractor plus several days of down time and that pump isn't easiest to get to either.
    My suggestion is that you may want to replace that valve to a different model now rather than later.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
Similar Threads
  1. JD TEK Generators
    By mechanic in forum Rural Living
    Last Post: 12-14-2012, 03:19 PM
  2. Yanmar 2210D V-Tek Loader
    By charlie brown in forum Owning/Operating
    Last Post: 08-27-2012, 05:32 PM
  3. Thumb Bro-Tek install
    By Rustyrat in forum Attachments
    Last Post: 08-07-2011, 07:52 AM
  4. Bro-Tek
    By beckmurph in forum Kubota Owning/Operating
    Last Post: 07-30-2009, 08:20 PM
  5. Barn tek
    By Anonymous Poster in forum All Other Brands
    Last Post: 03-26-2002, 09:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
