kenmac
Super Member
- Joined
- Feb 13, 2005
- Messages
- 9,709
- Location
- The Heart of Dixie
- Tractor
- McCormick CX105 Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
You are trying to stick 2 bearings in the same hole. Look at the pictures,use the 2 dowels for reference.The shaft for the clutch pack has no bearing.The middle shaft has a bearing on it,and the hole it goes into is the one already in the case. Did the one for the clutch pack fall off,and you stuck it on the wrong shaft? Mickey_Fx already pointed this out.
Looks that way. There is already a bearing in the case & it looks like he has installed another bearing on that shaft. Seems to me he needs to remove that bearing & install it on the power shift shaft
