Results 1 to 3 of 3
  1. #1
    Join Date
    Nov 2012
    Posts
    82
    Lavonia, GA
    Yanmar 1700
    Default Ym 1700 temp sending switch/ oil pressure sending switch change out
    Ok got parts today. I am changing out my temp switch, oil switch, and warning light bulbs tomorrow. What is the test to check the operation of the instrument lights? It would be nice to know they are functional. In the oil port there is a gauge installed. Its good to have but you cant see it while you are operating the tractor. I had just assumed have a light I can see. Anyone feel differently?
    I got the coolant tank installed. I bush hogged for about 1.5 hours today. No problems with over heating that I could tell, at least I didnt see any steam. I changed the oil and all the filters-oil, air, and fuel.
    Attached Thumbnails Attached Thumbnails Ym 1700 temp sending switch/ oil pressure sending switch change out-tractor-007-jpg
  2. #2
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,255
    gilmer tx
    Bobcat CT235
    Default Re: Ym 1700 temp sending switch/ oil pressure sending switch change out
    Is there a loose wire anywhere around where the oil gauge is installed. You are probably aware there are different switches for gauges and warning lights on both oil pressure and temperature. Your 1700 came originally with the warning lights. your oil light should come on when you turn the switch to the on position. Your temperature light should come on if you pull the wire off the sensor and touch it to ground with the switch in the on position.
  3. #3
    Join Date
    Nov 2012
    Posts
    82
    Lavonia, GA
    Yanmar 1700
    No there is no loose wire. Thats going to be a challenge but it should be easy enough to over come. There is a wire at the temp switch. I dont get a light when the wire is disconnected I tried touching it to bare metal. Maybe the bulbs are bad. I am also changing out bulbs
Similar Threads
  1. B7100 oil leak - sealing of oil pressure sending unit threads?
    By grossgary in forum Kubota Owning/Operating
    Last Post: 10-10-2012, 10:10 AM
  2. tc35d no electric - oil pressure sending unit?
    By DanReynolds in forum New Holland Owning/Operating
    Last Post: 08-13-2012, 01:00 PM
  3. Temp sending unit
    By Cavedog in forum Kubota Owning/Operating
    Last Post: 03-20-2012, 10:21 PM
  4. Case IH 385 oil pressure sending unit
    By geneP in forum Case-IH
    Last Post: 08-29-2010, 09:55 PM
  5. Replace oil sending switch?
    By Richard in forum Parts/Repairs
    Last Post: 07-31-2009, 08:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
