Results 1 to 8 of 8
  1. #1
    Platinum Member Scotty Dive's Avatar
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    Default Brake Boot leak?
    I was doing some maintenance on my 2020 - oil and filter, hydraulic filter an fluid change, fuel filter - when I noticed the boot to my brakes is seeping. What is behind here and is the boot just for protection? Just wanted to know before I called Hoye.
    Also - looks like there is a drain plug on the rear of the front drive shaft. What does that drain?
    Thanks,
    Scotty Dive
    Yanmar YM2020D "Git er Done Too"
    Pictures! http://s139.photobucket.com/albums/q...t=dfc00199.pbw
  2. #2
    Join Date
    Dec 2009
    Posts
    1,834
    gilmer tx
    yanmar 2002d
    Default Re: Brake Boot leak?
    You have wet brakes. Hydraulic/transmission fluid is behind it. I have torn and changed my boots before but I can't remember just how much fluid you will loose when you take the boot off. I'm thinking it wasn't that much but certainly not sure about it. This is what you need. http://www.hoyetractor.com/mm5/merch...Code=2020BRAKE
  3. #3
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    I would think that there is an oring or some sort of seal behind the boot? Or is it the boot that holds back the fluid?
    Thanks,
    Scotty Dive
  4. #4
    Join Date
    Dec 2009
    Posts
    1,834
    gilmer tx
    yanmar 2002d
    The boot is what holds the fluid. No o-ring. Boot just flexes as the brake rod goes in and out.
    Attached Thumbnails Attached Thumbnails Brake Boot leak?-scan0009.jpg   Brake Boot leak?-scan0008.jpg
  5. #5
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    Just an update - replaced the boot - very easy job....probably best when doing an fluid change though.....lost about half a quart of fluid. Not sure if more would have come out, but I replaced the boot as fast as I could to minimize the mess.
    Thanks,
    Scotty Dive
  6. #6
    Elite Member tallyho8's Avatar
    Join Date
    Aug 2004
    Posts
    3,140
    Katrinaville LA west of Westwego east of Ama south of River Ridge north of Boutte, above sea level
    Yanmar 1802, Kubota L4400
    I'm glad to know that Hoye has them in stock now. Mine in my 1802 started leaking about 8 years ago and I could not find one. I put a hot patch on it and it has held up so far but I always worry that it will start leaking again.
    Happy Trails!
    Dudley
  7. #7
    Join Date
    Feb 2010
    Posts
    648
    Ct
    Yanmar 2020D
    Default
    The boot came from Fredericks....I was looking for the hood emblems and Fredericks was the only place I could find them that said yanmar YM2020. Was tired of the tractor saying Zen noh and neighbors asking about it.
    Thanks,
    Scotty Dive
  8. #8
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    2,982
    Kansas
    YM3810D Yanmar
    My decals don't have the d either wouldn't mean anything to anybody but us I do understand your need for replacements however. I thought about having my graphics shop make me some but I sure intended to keep it a secret.
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
Similar Threads
  1. farmtrac 555 brake boot blowing out
    By whodat526 in forum Farmtrac
    Last Post: 05-01-2010, 11:54 AM
  2. brake line leak
    By srp323 in forum Hydraulics
    Last Post: 12-08-2008, 04:40 PM
  3. Oil leak or spray around shift boot
    By Bigbear in forum Chinese Tractors
    Last Post: 04-10-2005, 10:19 PM
  4. Minor brake fluid leak
    By RHughes in forum New Holland Owning/Operating
    Last Post: 01-10-2005, 03:46 PM
  5. YM1802 brake boot needed and info on US model #
    By Anonymous Poster in forum Yanmar
    Last Post: 06-07-2003, 08:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
