It isn't the kiss of death but it is the kick in the arse we all get sometimes with used stuff. If you have decent access to the cracked area a mig will probably do as good as anything on a nice clean surface.
A simple way to pressure test any radiator or cooling system (like after welding one etc) fyi is carefully put shop air into the overflow tube at the radiator neck with the rad cap on it and it will hold the amount of pressure the cap is calibrated at. You can overdo it if you dont back off but if careful it works fine. Use about 10-20 drops of dawn dish soap in a spray bottle with water and spray down the welded area and it will bubble if it isn't fixed.
Nickle arc welding rod is great too as long as you know how to use it. I have welded plenty of older Toyota exhaust manifolds with plain old mig 75/25 mix and mild steel .030 wire make it look like a stack of dimes keeps the heat down.
Disconnect the negative battery cable before doing any welding you dont want a fried alternator. :thumbsup:
