Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,592
    Greenwood Co., SC
    Yanmar YM2000
    Default Re: My 3 Point arms do not lift , Please advise
    Quote Originally Posted by chrivera View Post
    Also i would definitly replace that filter, that thing looks like it could be 10 years old!! maybe not but im sure it is old esp saying Japan on it. Probly has not been changed since the Jap farmer that had it put it on there!!
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  2. #12
    Join Date
    Apr 2007
    Posts
    705
    Central Ohio
    Yanmar 2402D
    Is there some sort of handwheel for a speed control below the front edge of the seat that you can hit with your boot when you get on and off? Some of the YM models have this, try turning counter clockwise if it does.
  3. #13
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    I was wondering about the possibility he bumped a lever or knob also those F series appear to have quite a few of them. I would cut the old filter apart and spread it out just to see whats in the system it has caught and get an idea if that was contributing to the problem.
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  4. #14
    New Member chrivera's Avatar
    Join Date
    Oct 2012
    Posts
    9
    Santiago
    F20D YANMAR
    Quote Originally Posted by clemsonfor View Post
    Hey Clem,
    Finally I could work in my F20 at weekend.
    I replaced the trans/hyd fluid, it had the ATF (red) and I put an Universal Tractor Fluid for both Hyd and Trans.
    I replaced the Hyd/Trans Filter.
    I cleaned the Screen....
    And guess what....
    It starting working again !!!!
    Thanks a lot for all your Help guys!!!
    I did replaced the Engine Oil and filter as well...
    Best Regards,
    Charles
  5. #15
    Join Date
    Sep 2009
    Posts
    8,592
    Greenwood Co., SC
    Yanmar YM2000
    glad to hear that.
    I often wonder those tractors that stop working cause of the fluid and filter being clogged up, how many hours were on them?? When i cange my fluid yearly or every other year having maybe 75 hours on it, it looks just like it came out oif bucket, with minimal stuff on the screen. Even multiply that by 5 to get to about the 500 hour change and i cant see that much crud!! I mean those systems must have just been neglected for years?
  6. #16
    Super Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    7,640
    The Heart of Dixie
    Yanmar3110D, Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
    Hey Clem,
    And guess what....
    Best Regards,
    Charles
    Glad to hear there were no major problems. Amazing what new fluid , filter , screen cleaning will do
Similar Threads
  1. 3-Point Hitch FX24D 3-Point Arms Don't Lift
    By rbecker in forum Yanmar
    Last Post: 05-30-2012, 05:46 PM
  2. 3-Point Hitch towing from bar across 3 point lift arms
    By jd49 in forum Owning/Operating
    Last Post: 04-02-2011, 08:48 PM
  3. Three point lift arms
    By cop in forum New Holland Ag Tractors
    Last Post: 01-26-2011, 12:25 PM
  4. Three point hitch lift arms not working
    By mchild in forum Parts/Repairs
    Last Post: 11-15-2005, 09:05 AM
  5. 3 Point LIft Arms Bent
    By jay_ch28 in forum Parts/Repairs
    Last Post: 05-24-2004, 04:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
