Results 1 to 8 of 8
  1. #1
    New Member mjdupre's Avatar
    Join Date
    Nov 2007
    Posts
    16
    Chicago(work)/Kentucky(play)
    Yanmar 1500 (Red)
    Default 1500 loses power when hot
    I have a 1500 that starts like a champ but once it gets hot it loses power.
    I suspected the head gasket, coolant looks really dirty shortly after I changed it though I don't see any coolant in the oil.
    Assume that a quick compression test on it may shed some light, though the fact that it starts easy leads me to believe that the compression is fine.
    Anyone have any idea what sort of compression these should have?
    How do you go about checking the compression on a diesel ????? (no seriously how ??)
    Mike
    Give a man a fish and he eats for a day....
    Teach and man to fish and he'll spend thousands on a
    fishing boat, sit in it all day drinking beer and telling lies.
  2. #2
    Elite Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    4,584
    The Heart of Dixie
    yanmar 3110D
    Default Re: 1500 loses power when hot
    Quote Originally Posted by mjdupre View Post
    Hot as in temp light on hot?? Doubt you have a comp. problem as, you state it starts right up. To check comp. you have to pull injectors. Hoye sells a test kit
    Yanmar 3110D
    07 Dodge 2500 5.9 Cummins
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    North Star 4 K PSI pressure washer
    Yamaha Timber wolf
    Liquid Logic Coupe Kayak
    16' Towmaster Dump Trailer
    20' Yanmar Hauler
  3. #3
    Join Date
    Dec 2009
    Posts
    1,827
    gilmer tx
    yanmar 2002d
    Crank it cool with the radiator cap off and watch for bubbles in the radiator. Bubbles will indicate a bad head gasket. Is your level in your overflow bottle staying the same? Starting right up is a good indication there is nothing wrong with your compression.
  4. #4
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    5,614
    Greenwood Co., SC
    Yanmar YM2000
    how old is your fuel filter?
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  5. #5
    Gold Member
    Join Date
    Jan 2012
    Posts
    316
    YM2000
    Quote Originally Posted by clemsonfor View Post
    No mention of any loss of Antifreeze. A bad HG. you usally have a Loss of Antifreeze.Out the Exhaust or in the oil. If no loss of Antifreeze and your not pressuring up the Radiator. No mention of that is why I agree with Clemsonfor. Whats up by the way!!!!
  6. #6
    Join Date
    Sep 2009
    Posts
    5,614
    Greenwood Co., SC
    Yanmar YM2000
    We don't know if he has antifreeze loss or not, so not knowing that is why I just thinking filter maybe??
    Bad filter will cause loss of power.
    Been doing good, busy here with work. Staying warm in this cool snap?
  7. #7
    Gold Member
    Join Date
    Jan 2012
    Posts
    316
    YM2000
    Staying warm in this cool snap?[/QUOTE]
    Have to. Still about like Sunlight to a Vampire.
  8. #8
    Join Date
    Feb 2005
    Posts
    4,584
    The Heart of Dixie
    yanmar 3110D
    Well, he hasn't been back so, I guess it's not too important
    Yanmar 3110D
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    Yamaha Timber wolf
    20' Yanmar Hauler
Similar Threads
  1. TC24D loses power
    By jlema in forum New Holland Owning/Operating
    Last Post: 11-28-2011, 09:40 AM
  2. Case 580E Loses Forward when hot
    By jcmitchell74 in forum Construction Equipment
    Last Post: 09-30-2011, 01:07 AM
  3. Mowing LX188 loses power
    By Creekpaddler in forum John Deere Owning/Operating
    Last Post: 04-26-2011, 05:34 PM
  4. L245 loses power
    By estodd in forum Kubota Owning/Operating
    Last Post: 09-15-2009, 04:25 PM
  5. 2006 TC 40 A - Hydralic loses power when hot
    By JNB in forum New Holland Owning/Operating
    Last Post: 08-07-2008, 01:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
