Page 4 of 11 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 102
  1. #31
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    3,080
    Kansas
    YM3810D Yanmar
    Default Re: Power Beyond vs Series for loader valve?
    I need to just get working on mine all this talk has revitalized my ambition to have a loader that works.
    I have had the PB sleeve and plug since last year mid season and had it planned to do this winter anyway just had too many other projects so far. I will probably take some pics also.
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #32
    Bronze Member ghenges's Avatar
    Join Date
    Apr 2012
    Posts
    84
    Greensburg PA
    Farmall
    Quote Originally Posted by J_J View Post
    3/8 in ID hose will handle 5 GPM.
    Interactive Nomogram for Sizing Hydraulic Hoses
    Grab the yellow dot and pull it to the 5 GPM mark, and you will see that the 3/8 in hose would be sufficient .
    The 5 GPM mark is Imperial gallons. Multiply by 1.2 to convert to U.S. Gallons = 6 gallons
    A 3/8" line is still adequate for the pressure lines. (Although personally, I would use a 1/2" line for the inlet to the valve.)
    At the recommended maximum velocity for return lines the nomogram indicates about a 9/16ths ID hose.
    However, since the pump on California's tractor puts out about 4.5 GPM, a 1/2 inch line for the return would probably be adequate.
    Remember this is calculated from the maximum velocity for return lines.
    Note: Yanmar had an optional pump available that put out about 5.8 GPM.
  4. #33
    Join Date
    Apr 2012
    Posts
    84
    Greensburg PA
    Farmall
    Quote Originally Posted by ghenges View Post
    A 3/8" line is still adequate for the pressure lines. (Although personally, I would use a 1/2" line for the inlet to the pump.)
    Click image for larger version.
    Incidentally, Yanmar employs a 22mm (19mm ID) steel hydraulic tubing return line on tractors (with John deere tin) that put out 4.5 GPM.
    19mm ID equates to .7467 inch, pretty darn close to 3/4".
    So Kenmac's problem being solved when increasing his return line to 3/4" would seem to be consistent with Yanmar engineering.
  5. #34
    Elite Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    4,628
    The Heart of Dixie
    yanmar 3110D
    Quote Originally Posted by winston1 View Post
    Any description on the possible fitting and just what it does?
    I guess you would have to purchase the part from the valve manufacture. Where the PB sleeve goes on my valve is under a large plug. Remove the plug and screw in another fitting ( PB sleeve).The PB sleeve has a hole drilled into it (I got mine from the valve manfacture) then, install a fitting to supply pressure to a down stream function. ie, 3 PT, grapple,logsplitter,valve, etc,.
    here's a pic of a PB sleeve http://www.google.com/imgres?imgurl=...QEwCA&dur=8889 Not saying the 1 in this pic will work in your valve
    Yanmar 3110D
    07 Dodge 2500 5.9 Cummins
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    North Star 4 K PSI pressure washer
    Yamaha Timber wolf
    Liquid Logic Coupe Kayak
    16' Towmaster Dump Trailer
    20' Yanmar Hauler
  6. #35
    Join Date
    Dec 2009
    Posts
    1,898
    gilmer tx
    yanmar 2002d
    Thanks for your reply kenmac. May see if I can find any kind of contacts for Akon so maybe they can tell me just what I have. JJ, ghenges, can either of you confirm or guess that I have a pb opening?
  7. #36
    Platinum Member Scotty Dive's Avatar
    Join Date
    Feb 2010
    Posts
    651
    Ct
    Yanmar 2020D
    winston - did you try this site for your valve? AKON HIDROLIK
    Thanks,
    Scotty Dive
    Yanmar YM2020D "Git er Done Too"
    Pictures! http://s139.photobucket.com/albums/q...t=dfc00199.pbw
  8. #37
    Join Date
    Dec 2009
    Posts
    1,898
    gilmer tx
    yanmar 2002d
    Quote Originally Posted by Scotty Dive View Post
    I did look on that sight a little. Couldn't find my valve but did notice all the different ones I looked at all had 30bar backpressere which I think translates to about 430psi. Got to go right now but I may try emailing them for what it is worth. Thanks for your help.
  9. #38
    Elite Member California's Avatar
    Join Date
    Jan 2004
    Posts
    4,935
    Sonoma County
    Yanmar YM240 and YM186D
    ... Hoye includes a part number HA-39 in their power steering kit that allows you to easily dump into the oil dipstick hole - See the Power steering instructioions here: http://www.hoyetractor.com/techhelp/...STRUCTIONS.pdf
    I just got a reply from Hoye - that Dipstick Hole Return Fitting isn't available aside from the entire PS kit.
    It looks like the only way to run Tank Return into the dipstick hole is to stack some standard hydraulic and plumbing fittings. (Plus a plug with a new longer dipstick). It's not under pressure so this isn't a critical component like the pressurized lines. Back to the drawing board.
  10. #39
    J_J
    J_J is online now
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,652
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    You can only tell by looking.
    If it has a 1/4 hex screw inside the valve port, it could be PB adaptable.
    If there is a ridge for the PB sleeve to sit and block off the fluid, then it is PB adaptable.
    It could also be a side tank port.
    If it is the sleeve type fitting, you will have to get it from the manufacturer.
    Can you open that port and show a pic of the inside?
    P = pressure, is stamped on the IN port
    T = tank port for the large hex plug. Probably optional tank port.
    Sometimes you see PB, PBY, BY
    Attached Thumbnails Attached Thumbnails Power Beyond vs Series for loader valve?-pb-hex-screw.jpg   Power Beyond vs Series for loader valve?-pb-adapter.jpg
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  11. #40
    Join Date
    Jan 2004
    Posts
    4,935
    Sonoma County
    My new LVT valve came with the PB outlet capped and a PB adapter like this packed separately. If this internal plug is installed, it appears to isolate the PB outlet circuit from the Tank outlet circuit inside the valve, routing each to its own opening.
    (stock photo)
    Added - oops I see JJ already said that.
Similar Threads
  1. torn polyethylene water tank - repair or return?
    By dejswa in forum Rural Living
    Last Post: 03-09-2012, 12:21 AM
  2. Replies: 13
    Last Post: 12-18-2010, 12:11 AM
  3. Replies: 2
    Last Post: 03-31-2009, 06:02 PM
  4. B7100HST tank return -- what size/type fitting
    By jas67 in forum Kubota Owning/Operating
    Last Post: 03-30-2009, 10:37 PM
  5. Oil & Fuel L3130, does the fuel bypass and return to tank?
    By Theowegian in forum Kubota Owning/Operating
    Last Post: 12-25-2004, 02:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
