Results 41 to 50 of 102
01-31-2013, 03:03 PM #41
Re: Power Beyond vs Series for loader valve?
Thanks,
Scotty Dive
Yanmar YM2020D "Git er Done Too"
Pictures! http://s139.photobucket.com/albums/q...t=dfc00199.pbw
01-31-2013, 03:09 PM #42
JJ - the only mention of Bailey-Chief loader valves I could find in google aside from the Bailey website is in an old TBN post where you included them in a list. Do you know anyone who has written about them or used them? Bailey's website doesn't show much description and I wonder if there is more information out there somewhere. Thanks!
01-31-2013, 03:16 PM #43
If i were doing this professionally for someone else I would probably do that. But for my own use - if I do this at all, it will likely be just common fittings stacked. Something like Adapter(s)/Nipple/Tee/Plug drilled for longer dipstick. Not elegant, merely functional.
01-31-2013, 03:21 PM #44
for what it's worth here is a photo of the bib 2 spool control I'm using, there is one port been plug off, not sure what it would be for
also a pix of the way I currently have the dump line installed into the dipstick hole, after Looking at it again, the bottom part of thread adapter was nothing more than a steel plumbing bushing, it thread right in place with no problems, why could we not use a longer pipe say 2" this same size in diameter have it threaded on both ends, tap into the side of it to install the dump line, Leaving the top to adapt for the use of the dipstick,....Never judge a man until you've walked a day in his shoes,
01-31-2013, 03:41 PM #45
The small pic that JJ posted is like the sleeve in my prince valve I used for my grapple. The larger pic is like the 1 in my loader valve.Looking at Winstons valve, you can't tell which lines he's using for what. Just a guess ,but it looks like he has 2 ports he could use for tank 1 on top & 1 on the side. The plug on the bottom maybe for PB or just another location he could have supplied pressure to the valve
Yanmar 3110D
07 Dodge 2500 5.9 Cummins
Husky 372xp
Husky 55 Rancher
Maruyama trimmer
Husky trimmer
Redmax BP blower
Toro zero turn
North Star 4 K PSI pressure washer
Yamaha Timber wolf
Liquid Logic Coupe Kayak
16' Towmaster Dump Trailer
20' Yanmar Hauler
01-31-2013, 04:22 PM #46Veteran Member
- Join Date
- Dec 2009
- Posts
- 1,833
- Location
- gilmer tx
- Tractor
- yanmar 2002d
Tied up the rest of the afternoon and have to go to Dallas tomorrow so I will be checking more on the two ports when I can. Thanks to everyone for your thoughts and suggestions.
01-31-2013, 04:37 PM #47
From the LV Valve Manual
01-31-2013, 04:56 PM #48Veteran Member
- Join Date
- Jan 2010
- Posts
- 1,875
- Location
- Northern, IL
- Tractor
- Branson 2400H
California,
Does you tractor have a seperate relief before the directional valve? If NO that is the pressure stacking mentioned by another poster.
Brief explanation of what happens:
Most relief valves have there spring chamber connected to the tank port. By effectively blocking the tank line by using the 3PH the relief will NEVER open..
So you must have either a relief before the loader directional valve or a relief between the loader valve and the 3PH to make a system that protects all components from extreme pressures. This still does not eliminate the problem of potentially blowing seals on the loader valve but would significantly help reduce this problem.Artificial Intelligence will never overcome natural stupidity.
Branson 2400H MMM & FEL
JD 112
BX1850 gone but not forgotten
01-31-2013, 07:45 PM #49
It must be in there somewhere or Yanmar wouldn't recommend putting a loader valve in series ahead of the 3-point. Here's Yanmar's description for using the factory-installed 'divider block'. I copied this from YM240 Operation Manual.
And mine. It has run plumbed this way since new, 30+ years.
Can anyone make sense of the relief circuit in this OEM shop poster? (copied from an ebay listing. Now I wish I had bought it.)
Yanmar Service Manual (Hydraulic Device) Model YM240 has additional information that doesn't appear in the Operation Manual.
"The control valve attached to Port A [Divider Block] should be a 'five ports and three actions' type. When this valve is used, make sure that the Tank port is connected directly to the reservoir."
And the following diagram.
Ok, great. I've never found anything explaining where to 'directly enter the reservoir'.
And a more direct answer to oldnslo's question whether there is a relief ahead of the 3-point control - I still don't know. Maybe somebody can interpret this system diagram. It just gives me a headache.
(Note we are talking about Outlet A, while B is unrelated).
('Outlet A' in both diagrams is the Divider Block shown in the Operation Manual and my photo).Last edited by California; 02-01-2013 at 03:56 PM.
01-31-2013, 10:56 PM #50
I like that! It didn't occur to me that the threads would be US Pipe size. That simplifies everything.
Checking the fluid level with a separate dipstick a few times a year would be no big deal.
Incidentally this picture and mine above also showing the shifter, illustrate that there is no place to drill a return into the top of the transmission on these models.
Similar Threads
torn polyethylene water tank - repair or return?
By dejswa in forum Rural LivingReplies: 13Last Post: 03-09-2012, 12:21 AM -
Cannot figure out how to return back to tank / resevoir?
By gsdavis1 in forum HydraulicsReplies: 13Last Post: 12-18-2010, 12:11 AM -
FEL Power beyond w/o return to tank line (only two hoses)???
By jas67 in forum HydraulicsReplies: 2Last Post: 03-31-2009, 06:02 PM -
B7100HST tank return -- what size/type fitting
By jas67 in forum Kubota Owning/OperatingReplies: 2Last Post: 03-30-2009, 10:37 PM -
Oil & Fuel L3130, does the fuel bypass and return to tank?
By Theowegian in forum Kubota Owning/OperatingReplies: 2Last Post: 12-25-2004, 02:24 PM
