Results 71 to 80 of 102
02-02-2013, 06:03 PM #71Veteran Member
- Join Date
- Dec 2009
- Posts
- 1,827
- Location
- gilmer tx
- Tractor
- yanmar 2002d
Re: Power Beyond vs Series for loader valve?
The metric 1.5 thread gauge seems to fit the threads right on. 19tpi would equate to about 1.3 metric. Sure not positive but another thing that makes me think it is a straight thread is because it is a short thread, I would guess about 3/8" long. I'm still holding my breath "Akon" will respond this next week. Maybe Neat 1500 will shed more light for me.
02-02-2013, 09:07 PM #72Veteran Member
- Join Date
- Jan 2010
- Posts
- 1,874
- Location
- Northern, IL
- Tractor
- Branson 2400H
M16 x 1.5 is standard size of metric fitting so it could also be that. Normally these types of fittings would have a flat spotface and or a chamfer on them like an american SAE O-ring port.
best of luck on getting the proper fitting and getting your tractor back in operation.Artificial Intelligence will never overcome natural stupidity.
Branson 2400H MMM & FEL
JD 112
BX1850 gone but not forgotten
02-02-2013, 09:37 PM #73Veteran Member
- Join Date
- Dec 2009
- Posts
- 1,827
- Location
- gilmer tx
- Tractor
- yanmar 2002d
Thanks again for your willingness to shed light. The surface does have a little chamfer or bevel on it. I am in operation but have been convinced I'm just not plumbed correctly. I have had absolutly no problems without the power beyond port but still want to do it correctly if possible without buying a new valve or something.
02-02-2013, 09:43 PM #74
Ok its all back together.
I plumbed the new loader valve the same way it had been for 30 years, with the valve's Out port in series ahead of the 3 point control.
Everything works properly.
Bonus photo! While I was working, this little guy (juvenile coyote, or fox?) came across the front of my open-front tractor stall. He was following a scent and was unconcerned that I noticed him. By the time I reached the camera he seemed annoyed, and departed - moving toward me a few yards (photo) so he could go around the other side of the house.
Last edited by California; 02-03-2013 at 05:29 PM. Reason: Critter pix retitled 'CoyoteOrFox'
02-03-2013, 04:30 AM #75
02-03-2013, 07:14 AM #76Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,462
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Do you have any reference for your statement about the shaft key.
I just never knew you could select a woodruff key to shear at a selected torque.
In general, a shear key is supposed to be weaker than the surrounding metal .
Shaft Keys - Types and Their Design
Diagram at the bottom of page will explain how compute the torque required to shear.Last edited by J_J; 02-03-2013 at 07:41 AM.
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
02-03-2013, 08:00 AM #77Veteran Member
- Join Date
- Dec 2009
- Posts
- 1,827
- Location
- gilmer tx
- Tractor
- yanmar 2002d
Thank you neat 1500 for the pictures. I know what I need to do now. Only thing holding me back is identifying and procuring whatever fitting is in that top plug hole. Hoping "Akon" will respond but dubious.
California, I have pretty much destroyed your thread. I should have started a new one so I apologize to you and good to know you are up and going with your new valve. We have the coyotes pretty thick here in East Texas. That one almost looks to young to be out on his own.
02-03-2013, 03:25 PM #78
Winston, don't worry about distracting my inquiry. We have both received a lot of good advice. This thread has accumulated a lot of information that will be helpful to other owners who research this in the future.
For me, I learned that replacing my loader control in series is 'good enough for the girls I go with'
as an old Carpenter buddy used to say. In contrast to this, the 'Best Practices' solution is a separate Tank Return like that Kubota dealer started doing.
Also using series configuration, the 3-point lever must be at Down or Hold (not Lift!) so it isn't making back pressure, any time the loader controls are used. If that were in Lift position then the back pressure from the 3-point may be additive to the pressure allowed by the loader control's relief valve.
And finally, my wife saw the critter picture and is sure that's a fox, not coyote. Anybody know? For comparison here are coyote pictures I posted a year ago and below is one from two weeks ago. I still think from the little guy's behavior following a zig-zag scent on the ground and ignoring me, he was probably a baby tracking where Mommy went.
02-03-2013, 04:13 PM #79Veteran Member
- Join Date
- Dec 2009
- Posts
- 1,827
- Location
- gilmer tx
- Tractor
- yanmar 2002d
After looking at numerous pictures I may have to agree with your wife. Might be a California grey fox. california foxes grey - Bing Images
02-05-2013, 05:30 PM #80
You nailed it! I sent the photo to a friend who is a wildlife biologist with F&G. Just got this back:
That is an adult gray fox. Remarkably they live in close contact with people because they don't perceive us as threats. Every year I speak to at least a dozen people where foxes have had litters under their porches. Pups are frolicking on their patio furniture and even try to enter the house. My guess is that the fox could be denning in the barn - I would not be surprised to see pups around in the spring.
Similar Threads
torn polyethylene water tank - repair or return?
By dejswa in forum Rural LivingReplies: 13Last Post: 03-09-2012, 12:21 AM -
Cannot figure out how to return back to tank / resevoir?
By gsdavis1 in forum HydraulicsReplies: 13Last Post: 12-18-2010, 12:11 AM -
FEL Power beyond w/o return to tank line (only two hoses)???
By jas67 in forum HydraulicsReplies: 2Last Post: 03-31-2009, 06:02 PM -
B7100HST tank return -- what size/type fitting
By jas67 in forum Kubota Owning/OperatingReplies: 2Last Post: 03-30-2009, 10:37 PM -
Oil & Fuel L3130, does the fuel bypass and return to tank?
By Theowegian in forum Kubota Owning/OperatingReplies: 2Last Post: 12-25-2004, 02:24 PM
