Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    16,915
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    Default Re: suitcase weights
    Quote Originally Posted by Grumpy Old Man View Post
    Now you got me thinking and I called the local JD dealership they priced me at $90.00 each back in December and had to order them , That's why I started looking else where Now 5 minutes ago they priced me at $35.00 each and had 9 in stock ?? I guess they must have an overstock ?? Still glad you made me think about this today ,Thanks everybody gotta go warm up the truck !
    Now you're talking!!! .83 per lb. Not bad at all for new weights that are the specific dimensions and weight that you want!!!
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  2. #12
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,550
    Greenwood Co., SC
    Yanmar YM2000
    just noticed that the weights on the link are "REAR" weights? Did not know there were rear weights, are these the same one like in the pics and that hang on a front bumper?
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  3. #13
    Bronze Member lancem's Avatar
    Join Date
    Oct 2009
    Posts
    58
    Martin,Ga
    YM2000
    Default
    Yes. They fit great on the front of my ym2000.
  4. #14
    Join Date
    Nov 2012
    Posts
    1,003
    Tennessee foothills
    John Deere and Case
    Quote Originally Posted by clemsonfor View Post
    Maybe listed that way because they only sell lawn tractors ? I want this style because I can hang them in front or off the box blade .
  5. #15
    Advertiser
    Join Date
    Jun 2005
    Posts
    201
    Washington
    we sold 25lb jinma weights for $25 the best shipping was USP flat rate box
    Coldwater Tractors, Inc.
    www.coldwatertractors.com
  6. #16
    Veteran Member deepNdirt's Avatar
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    was either over the past weekend or earlier this week I seen some on CL for sale here in Ga, it had to be either Athens or Atlanta as they are the only 2 places I look at, Might be worth looking them up if still available, I suppose the drive to get them might be cheaper than the cost to ship them,
    if you still need them I'll try looking back for them,
    Oh they are closer than I remembered 5 miles up the road,
    http://athensga.craigslist.org/bar/3540824348.html
    Never judge a man until you've walked a day in his shoes,
  7. #17
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,808
    Waynesboro Va
    John Deere X310, JD LA 145
    Look on search tempest it will search cragslist and ebay in a set circle around you, you set the miles. You would be surprised what is out there.
  8. #18
    Super Member California's Avatar
    Join Date
    Jan 2004
    Posts
    9,625
    Sonoma County
    Yanmar YM240, and now just one YM186D
    I got 240 lbs of weights that had been on a tractor with a larger bumper, and made a shim from a 4x6 faced with steel plate to match up the mounting dimensions. Everything fits snug and is secured with bolts. Here's a photo from a couple of years ago.
    I subsequently found and adapted iron weights for the rear wheels too. Thread with photos - adapting the rear wheel weights to fit.
    Then my neighbor gave me 200 lbs of weights from scrapped exercise equipment. Each is the size of a paperback novel and weighs 10 lbs. I used two of them to fill the cavity on the front of my front weights. If you stand back far enough - it doesn't look too bad.
    Total iron ballast 410 lbs for $120. Plus filled tires. Finally I have enough traction to haul my watering trailer (weighs more than the tractor) uphill.
  9. #19
    Join Date
    Jan 2012
    Posts
    1,113
    YM2000
    Total iron ballast 410 lbs for $120. Plus filled tires. Finally I have enough traction to haul my watering trailer (weighs more than the tractor) uphill.[/QUOTE]
    Here's my on the cheap extra balast thanks to a few of our local lakes. It's filled with lead from a collection of lost anchor's. Hefty 75Lbs.easy. Only 2wd and since I just needed to add for when the FM. is attached and trailering. Also make's for a great bumper.
    Attached Thumbnails Attached Thumbnails suitcase weights-003-jpg
  10. #20
    Super Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    7,596
    The Heart of Dixie
    Yanmar3110D, Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
    Have you already bought weights ? If you'er close you could drive over and pick them up. Call Fredricks in NO. AL. He use to sell them. Don't know the price
    A Fredricks Yanmar 3110D
    07 Dodge 2500 5.9 Cummins
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    North Star 4 K PSI pressure washer
    Honda 300 4 trax
    Yamaha Timberwolf
    liquid logic coupe kayak
    16' Tow Master Dump Trailer ,20' Yanmar Hauler
Similar Threads
  1. Suitcase Weights for a BX
    By 94BULLITT in forum Kubota Owning/Operating
    Last Post: 02-10-2013, 10:03 AM
  2. suitcase weights
    By coldstream in forum Owning/Operating
    Last Post: 04-18-2010, 11:09 PM
  3. Suitcase weights
    By Deere Hunter in forum John Deere Buying/Pricing
    Last Post: 03-11-2008, 03:01 PM
  4. Ballast Suitcase Weights
    By Lt74 in forum Cub Cadet Tractors
    Last Post: 11-11-2005, 09:52 PM
  5. Ballast Suitcase weights
    By normde2001 in forum Yanmar
    Last Post: 04-22-2002, 03:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
