Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Default Re: LED headlights and light bar for YM2620D - pics and summary
    Nice work. BTW, welcome aboard.
    The PUPIL who does not surpass his Master, fails his Master.
  2. #22
    Platinum Member rwork's Avatar
    Join Date
    Apr 2012
    Posts
    605
    Mississippi Gulf Coast
    Kubota B6100 LS R3039H
    Quote Originally Posted by doctorwho00 View Post
    Thanks 284-international! The tubing is just some thin wall electrical conduit from the electrical aisle at Lowes. I got a fairly cheap bender kit at NorthernTool and made the bends.
    Which bender did you get to make those? I've been looking for an affordable tube bender to make some smaller radius bends in some 3/4 and 1" tube/conduit. All I saw at northern tool was either for brake line size tubing, or a pretty expensive hydraulic bender. ???
  3. #23
    New Member doctorwho00's Avatar
    Join Date
    Feb 2013
    Posts
    14
    Lynchburg, TN
    Yanmar 2620D
  4. #24
    Join Date
    Feb 2013
    Posts
    14
    Lynchburg, TN
    Yanmar 2620D
    Hi 284 International, here is a before and after shot of just the headlights.
    BEFORE (OEM High Beams)
    LED headlights and light bar for YM2620D - pics and summary-oldlights-jpg
    AFTER
    (LED High Beams)
    LED headlights and light bar for YM2620D - pics and summary-ledhigh-jpg
    (LED Low Beams)
    LED headlights and light bar for YM2620D - pics and summary-ledlow-jpg
  5. #25
    Bronze Member lancem's Avatar
    Join Date
    Oct 2009
    Posts
    58
    Martin,Ga
    YM2000
    Default
    Very nice!!
  6. #26
    Join Date
    Jun 2010
    Posts
    1,463
    Southern California
    International Harvester 284, Yanmar 1401D, Yanmar 240...etc
    Wow, that looks to provide ample lighting even with the headlights only. With the light bar on too I imagine it would be even better. Thank you for the photos. I need to start doing some scheming and pondering on what steps I will take.
  7. #27
    Join Date
    Oct 2008
    Posts
    86
    Outstanding project outcome. Did you have to do any alterations to the generator. What was the amp draw of the lights. Do you remember who you bought them from on EBay?
  8. #28
    Join Date
    Feb 2013
    Posts
    14
    Lynchburg, TN
    Yanmar 2620D
    knotweed, the eBay seller is at eBay My World - power-bulbs. I purchased the light bar from this eBay reseller and the LED headlights from NorthernTool. The amp draws are as follows:
    LED headlights (low beams): 2.5 amps
    LED headlights (high beams): 5 amps
    LED light bar: 6 amps
    The original OEM headlights had two 50 watt bulbs in mine, so that's a draw of 8.3 amps. Given that, I can run the lightbar and the new headlights on low at the same time for right at the same amperage. LEDs put out more light as less amperage than incandescent bulbs by a pretty huge factor.
  9. #29
    Gold Member imgone52's Avatar
    Join Date
    Dec 2011
    Posts
    316
    Tompkins County, New York
    Cub Cadet Yanmar SC2400
    Nice job Doctor The bottom line is your sentence "I had a lot of fun"
    CCY SC2400, FEL, MMM, WB, Chore tote, Broadcast Spreader
  10. #30
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,541
    Greenwood Co., SC
    Yanmar YM2000
    WOW nice I just read this. Saw it earlier in the day and thought it was a post from several years ago that got dragged up when I saw that it was 3 pages!!
    I was thinking it was the guy that put LEDs in his headlights in the original bulb by cutting up some coke cans and then glueing the LED or whatever to the housing! I have been looking at LEDs for a long time for mine, but because my farm is not where I live and the tractor is there I don't have much use for night time work. I also don't work at night ever so its not a priority for my $$ right now!
    But glad to have you and nice post. Love it when a project is documented.
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
Similar Threads
  1. LED Headlights for B7100
    By Sherweld in forum Kubota Owning/Operating
    Last Post: 06-22-2014, 08:15 PM
  2. Mods #3&4 Forward LED light bar and Alley Lights
    By 4shorts in forum Customization
    Last Post: 01-07-2013, 06:31 PM
  3. Replies: 2
    Last Post: 10-10-2012, 04:54 PM
  4. LED light bar and rear work lights installed!
    By sidewinder770 in forum Attachments
    Last Post: 07-09-2012, 06:21 PM
  5. LED headlights???
    By jgrreed in forum Customization
    Last Post: 07-24-2010, 10:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
