Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Join Date
    Oct 2008
    Posts
    86
    Default Re: YM2002D Power beyond
    Where does this fitting (cast iron) go to?YM2002D Power beyond-yanmar-jpg
  2. #12
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    The cast iron fitting is a low pressure fitting and goes to tank.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #13
    Join Date
    Oct 2008
    Posts
    86
    Quote Originally Posted by J_J View Post
    Like the set up. Thanks for the clarifications.
  4. #14
    Join Date
    Oct 2008
    Posts
    86
    I also bought my tractor from LCI near Canton. I have the same valve but the cast iron 90 goes to the pipe to the 3 point (one that was cut) and the top outlet is plugged.
    Can I use this top outlet for remotes?
  5. #15
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    If you have that same valve, then you should install the PB screw and use that port for the remotes.
    After installing the remotes, add PB screw in the remote valve and run the PB out line to the 3pt.
    If you have installed everything correctly, you should have 7 hoses from the valve and one input port with a plug installed.
    J.J.
    Git er done.
  6. #16
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,179
    gilmer tx
    Bobcat CT235
    Mine also came from LCI. JJ is telling it correctly. He was my main source in getting it plumbed correctly.
  7. #17
    Join Date
    Oct 2008
    Posts
    86
    Thanks for the info.I knew this was the place for answers.
  8. #18
    Join Date
    Oct 2008
    Posts
    86
    Question: by you stating "run the PB out line to the 3pt." ,do you mean out to the area of the 3 point or do you mean it connects somewhere to the three point.
    I'm weak on hydraulics and I respect your direction.
    One last question: is the PB screw something I can buy or do i need to fabricate something like the original poster did.
    I think I will send you some pictures of my situation.
  9. #19
    Join Date
    Oct 2008
    Posts
    86
    I'll take some pictures and post.
  10. #20
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,179
    gilmer tx
    Bobcat CT235
    Not JJ but look at post #10, follow the line coming off the top of the valve and you can see where it attaches to the original cut tubing line that goes back to the 3 point control valve. The other end of the original cut tubing line is the pump discharge and goes into the lowest opening on the loader control valve.
    I doubt you are going to be able to access a new PB plug. I think those loaders were pretty much made for LCI Equipment and they went under.
    Just went out and made another plug. If your valve is like mine and you determine to go power beyond pm me with your address and I will mail it to you complete with o-ring. Looking forward to seeing your pictures.
Similar Threads
  1. YM2002D dynamo bearings
    By winston1 in forum Yanmar
    Last Post: 12-21-2012, 03:47 AM
  2. YM2002D engine code
    Last Post: 12-30-2009, 06:41 PM
  3. New Owner of YM2002D
    By vwbeetle in forum Yanmar
    Last Post: 12-28-2009, 09:34 PM
  4. YM2002D Hydraulics
    By tabnodak in forum Yanmar
    Last Post: 12-21-2009, 10:12 AM
  5. YM2002D closest US model?
    By RJB in forum Yanmar
    Last Post: 05-01-2004, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
