Page 6 of 10 FirstFirst ... 3456789 ... LastLast
Results 51 to 60 of 97
  1. #51
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,582
    Greenwood Co., SC
    Yanmar YM2000
    Default Re: Home built hiller
    least you have work! Wish I was near there maybe I could give you a hand. I wish I could have something I could put in a few hours after the 8-430 gig.
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  2. #52
    Gold Member Ginormous's Avatar
    Join Date
    Apr 2011
    Posts
    457
    Dayton, Ohio
    Yanmar YM2210
    Quote Originally Posted by Car Doc View Post
    Looks great Ginormous you did a nice job hope we hear a good report when you get it in the dirt!
    Thanks, Car Doc. Me too! Here in Ohio the avg last frost date is May 10, so I usually wait until after that to get things planted. This year we're going to be out of town from the 10-17, so hopefully the weather cooperates when I get back, or that garden will be a late start. Anyway... I'm thinking I may need to hang some extra weight on this, but I won't know until I'm in the middle of it.
    Yanmar YM2210, Taylor-way 5' finish mower, Woods 4' rotary mower, boom pole, hayride wagon; upgraded tractor with gas turbine engine plus strap on solid rocket motors for that extra boost of speed... but brakes only work when I'm on the ground.
  3. #53
    New Member
    Join Date
    Aug 2010
    Posts
    20
    Bush, LA
    Mahindra4525
    Quote Originally Posted by Ginormous View Post
    Paul -- sorry, haven't been on for a few days... I did buy those brackets for 2" square to 1 3/16" round. I got them at a place in Ohio called Buckeye Tractor. Here's there website: Buckeye Tractor Co They list them as 2" square to 1 1/4" round, but they work just great with the Agri-supply hillers that have 1 3/16" round shanks. They're not free, $18.69 each (part # 17500), so you might be able to make some for yourself using their simple design.
    Yeah, I looked at those. The set screw configuration looked like it may be more secure, but I'm going to go ahead and order the Buckeye brackets. Your advice on this is very helpful. Thanks.
  4. #54
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Home built hiller-img_1184-1280x960-jpgHome built hiller-img_1187-1280x960-jpgHome built hiller-img_1201-1280x960-jpgHome built hiller-img_1205-1280x960-jpg
    I took the time today to add a flattener and get it garden ready I built it so I can lower it down far enough to support the tool bar level when sitting.. It looks like if I don't get in the garden tonite there is 70% chance of rain and snow tomorrow and I would make so much of a mess out of it I would be who knows when getting in so I will post pics of how the garden turns out tomorrow hopefully.
    You guys with good eyes will notice the rear bar is bowed there on the right side I saw it and thought I had it crowned where I could balance the bow between the 2 strut bars. But using saw horses is not an exact science as far as welding. So I plan on using a 10 ton bottle jack and a good chain later before I paint it and fix that. So just so you don't think I am some kind of hack artist it really did bother me when I stood back and saw what I did. It will work fine I just like things as perfect as I can get them just me. fwtw
    The garden pics on this post are just me playing in the dirt the ground is as I left last year just tilled and sat all winter till now. I plowed it and disced it and tilled it Sunday so its prepped now and ready to be seeded once I get the hilling done. At least I am crossing my fingers I get the whole hilling thing figured out.
    Just for conversation but looking at my garden shack calender from last year-last wknd last year my corn was 6" tall and it was 97 degrees! Its 40 now and 28 supposedly the low wed nite. This means I need to go and shut the water back off at the garden and drain the pvc water line etc etc sheesh its getting old.
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  5. #55
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Quote Originally Posted by clemsonfor View Post
    Thanks for the offer I could use some now and then I would take you up on that if I could right now. I am one of the fortunate ones around here I pretty much stay busy year round. The problem I run into so often is I am the only one in the shop and I get overloaded pretty easy. Especially when they start showing up on hooks 3 at a time and get left here.
    I also only work 8-5 m-f I quit burning the candles at both ends 10-12 years ago it aint worth it looking back by how bad my body feels now.
  6. #56
    Super Member /pine's Avatar
    Join Date
    Mar 2009
    Posts
    7,550
    I like the idea of the bar that flattens the hill rows...I bought a tool bar and 14" discs last year...This year I'm adding S-tines with tips to cover the rear tire treads and I'm also adding a bar to flatten the beds...but I'm taking it a step further and behind the knock-down bar is three shallow furrows.. one on each side of the bed for seeds and a little deeper one in the middle for side dressing (fertilizer)...
    Taking it even a step further (future modification)..I will remove the furrow bar and add one or two seeder/planter hoppers and drive wheels...I plan to use the seeder/hopper assemblies that are used on the hand pushed seeders...they can be purchased as parts for the walk/push seeders for about $35. ea...if I go with the 2 row setup I may also set up a third hopper in the center to side dress...then add another bar at the tail to slightly backfill over the seeds/fertilizer...
    Slash Pine
    blunt and succinct yet sincere I don't suffer fools and morons...in the immortal words of Popeye..."I yam what I yam"
  7. #57
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Yup I can see some interesting mods as well! I think I will add a couple small shovels on spring shanks right behind the discs on the back bar to create an irrigation furrow on either side. I already plan on irrigating using the dip the disc creates but a shovel would do it better. Maybe a shovel right down the middle to irrigate heck if I know?
  8. #58
    Join Date
    Sep 2009
    Posts
    8,582
    Greenwood Co., SC
    Yanmar YM2000
    Safety police here!!! That looks like a trailer with MH axles! you know those things are one time use only right??? Your whole wheel could ffall off and you could kill the old lady planting flowers in her front yart with a loose tire.
    Haha...just had to get us on another tangent.
  9. #59
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,227
    gilmer tx
    Bobcat CT235
    Looking good. I'm anxious to see how your flattener works. I planted purple hulls and zipper cream peas this afternoon. Suppose to get down in the upper 30s here the next night or two but I'm speculating after that the ground is going to warm up fast. It is in the mid 80s this afternoon.
  10. #60
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Wow good eye Clemson haha! I even dropped them about 6 inchs that makes them even more unpredictable and dangerous!
    Man this weather is nuts Winston thanks again btw. I don't know but am sure crossing my fingers that the drought in my area is done gone don't know whats normal for you but we are below normal, temps in the 30's sounds low to me for you that far south?
Similar Threads
  1. Home made hiller project
    By Eyecatcher in forum Build-It Yourself
    Last Post: 08-27-2012, 09:15 PM
  2. my home built loader so far
    By john m in forum Build-It Yourself
    Last Post: 06-18-2011, 06:29 PM
  3. home built FEL
    By Chuck U&R in forum Yanmar
    Last Post: 02-11-2010, 11:18 PM
  4. Home built trailer
    By tractorboy5500 in forum Trailers & Transportation
    Last Post: 01-20-2010, 08:03 PM
  5. Home built cab
    By DEON in forum Customization
    Last Post: 09-22-2009, 10:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
