Page 8 of 10 FirstFirst ... 5678910 LastLast
Results 71 to 80 of 97
  1. #71
    New Member
    Join Date
    Mar 2013
    Posts
    22
    Weatherford okla
    Iseki & ford,1210
    Default Re: Home built hiller
    Quote Originally Posted by 6011Artist View Post
    Terry, that's good as snuff and not half as dusty...lol.
    I like it when someone recycles old stuff into new usuable stuff. It looks like it would work fine. After you figure out your angles you might want to weld them in place (hillers). I see the tires inside of the PVC pipe for a roller. Did you fill it with concrete for weight? Another great idea that'll get the job done.
    On the sweep on the rear, you will probably find you're going to have to replace that aircraft cable with a piece of flatbar or angle to hold your plow down on the ground. It looks like it will kick up when lowered into the dirt. Have you used it yet ?
    I did add concrete to the pipe. You were right about the cable , plow came out of the ground. I added a bigger plow and weight to hold the plow in the ground. Was able to play with it a little Works a lot better. Should be able to do some adjusting later this week if it doesn't rain.Its been really dry so will take all the rain we can get. This is a great site have learned a lot . Am working on a cultivator from ideas from this web site. So many ideas so little time.
  2. #72
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,179
    gilmer tx
    Bobcat CT235
    Car Doc, thanks for taking the time to share your hiller with us. Looks like it is going to work out great. I sort of like Terrydt100's floating roller idea. Don't know I will modify but I might if I get a little bored.
  3. #73
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Welcome and thanks for taking the time to look! I appreciate all the ideas that have been put on here hopefully someone will benefit on their next build.
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  4. #74
    Gold Member
    Join Date
    Aug 2008
    Posts
    373
    Darlington, SC
    1957 Ferguson 35, 1977? Yanmar 2200, 1963 Cub Cadet Original
    Clemson, sorry I missed that as being intended for a joke. You are right, lots of people think they are illegal and constantly jump at the chance to put the use of them down. I will add, they are unsafe if you don't know anything about them, especially how to properly install the tires. But with proper knowledge, a very heavy duty axle system.
    Ok, I'm laughing with you now....carry on...lol.
    modify, adjust and improvise....a country boy can survive
  5. #75
    Gold Member
    Join Date
    Aug 2008
    Posts
    373
    Darlington, SC
    hey Terry, this is a great site for learning to build equipment. I have several projects where I've accumulated the parts but haven't built them yet...one day though I'll do it.
    Try adding a solid piece of angle iron to that plow and use that to adjust the angle as well. Holding it rigid is the trick to it always being where you put it.
  6. #76
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    6011 I knew he was kidding that was the whole idea its tongue in cheek humor! There is always something just under the surface we have to try to be PC and SC on here.
    Heck I cut them apart and welded them added a 6" drop to lower the trailer and I can only imagine how many trouble free miles shes givin me I know I am on the 5 or 6th set of MH tires.
  7. #77
    New Member
    Join Date
    Aug 2010
    Posts
    20
    Bush, LA
    Mahindra4525
    Quote Originally Posted by Ginormous View Post
    Paul -- sorry, haven't been on for a few days... I did buy those brackets for 2" square to 1 3/16" round. I got them at a place in Ohio called Buckeye Tractor. Here's there website: Buckeye Tractor Co They list them as 2" square to 1 1/4" round, but they work just great with the Agri-supply hillers that have 1 3/16" round shanks. They're not free, $18.69 each (part # 17500), so you might be able to make some for yourself using their simple design.
    Bought those brackets from Buckeye. Regular delivery to south La. took only 3 days. Thanks again for the advice.
  8. #78
    Gold Member Ginormous's Avatar
    Join Date
    Apr 2011
    Posts
    457
    Dayton, Ohio
    Yanmar YM2210
    Paul -- Glad it worked out for you. I was glad I found them myself. I was debating about either making some brackets or buying ones that were double that price, but when I found those at Buckeye Tractor, I decided I'd rather spend buy those and use my time to work on other things.
    Yanmar YM2210, Taylor-way 5' finish mower, Woods 4' rotary mower, boom pole, hayride wagon; upgraded tractor with gas turbine engine plus strap on solid rocket motors for that extra boost of speed... but brakes only work when I'm on the ground.
  9. #79
    New Member
    Join Date
    Aug 2010
    Posts
    20
    Bush, LA
    Mahindra4525
    Ginormous,
    Was an easier decision for me because I don't know how to make them. But, if I keep looking at this site I might learn how. Welding interests me but I really don't have a clue. Re Buckeye, I like their stuff and was pleased with delivery/service. Thanks again.
  10. #80
    New Member
    Join Date
    Aug 2010
    Posts
    20
    Bush, LA
    Mahindra4525
    Pics of my hiller.Home built hiller-hiller-pieces-jpgHome built hiller-after-jpgHome built hiller-before-2-jpgHome built hiller-closeup-jpgHome built hiller-hiller-bar-attached-jpgHome built hiller-side-view-jpg
    Okra is finally in the ground. Thanks for all the help,
    Paul
Similar Threads
  1. Home made hiller project
    By Eyecatcher in forum Build-It Yourself
    Last Post: 08-27-2012, 10:15 PM
  2. my home built loader so far
    By john m in forum Build-It Yourself
    Last Post: 06-18-2011, 07:29 PM
  3. home built FEL
    By Chuck U&R in forum Yanmar
    Last Post: 02-12-2010, 12:18 AM
  4. Home built trailer
    By tractorboy5500 in forum Trailers & Transportation
    Last Post: 01-20-2010, 09:03 PM
  5. Home built cab
    By DEON in forum Customization
    Last Post: 09-22-2009, 11:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
