I took the valve off a ck'ed it, clean as can be. With air applied it ports to the rear housing where the lift control is. Then it returns to the valve by another port, if you hold your finger over this return port it blows the piston out. This return port on the valve side will not take air , seems to be plugged. I think this is the port to the piston but not sure, it does go to a relief valve also on the piston side. Now what? thanks, Larry /forums/images/graemlins/confused.gif
