Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
  1. #11
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Default Re: Problems getting Yanmar tractor running.
    It spins plenty fast but I didn't see much fuel getting out maybe just my connection etc? Doesn't someone on here usually reccommend tapping on the plungers to free them up? I think thats worth a try also be carefull its just little pistons inside operated by the camshaft though.
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  2. #12
    Join Date
    Jan 2012
    Posts
    1,109
    YM2000
    Problems getting Yanmar tractor running.-picture-021-jpgProblems getting Yanmar tractor running.-picture-090-jpgThose look to be for Bleeding the pump. Not Sure but on my YM2000 Pic.1 is the pump. Pic. 2 is the injectors. If your Injectors are similar First just loosen the Nuts and watch for fuel. If fuel shows up Remove An Injector and see what happens. If you have Spray a compression check is next while the Injector is out.
  3. #13
    New Member Sharkhunter's Avatar
    Join Date
    Apr 2013
    Posts
    14
    Bushnell, FL
    Cat 416C, Ford 4630, JD 750
    Quote Originally Posted by Car Doc View Post
    I will definitely give that a try. I've run across posts where that was discussed. Thanks
  4. #14
    Join Date
    Apr 2013
    Posts
    14
    Bushnell, FL
    Quote Originally Posted by careyo63 View Post
    Thanks for posting the pics. Your Yanmar resembles the one on my JD 750. This one I'm working on looks quite a bit different. I took some pictures that have better clarity than the video did. I will attempt to try and post them.
    Problems getting Yanmar tractor running.-025-jpg
    Problems getting Yanmar tractor running.-026-jpg
    Problems getting Yanmar tractor running.-027-jpg
    Problems getting Yanmar tractor running.-029-jpg
  5. #15
    Join Date
    Jul 2012
    Posts
    69
    Hanover County, VA
    John Deere 750, John Deere X540, Wallenstein BXMT3213 chipper shredder, Befco bush hog
    I'm no expert on diesel engines, but it sounds like you might want to first make sure you are bleeding the system using the proper procedure for that engine.
    Can you locate a user manual and follow the specific bleeding instructions for that model Yanmar?
    I have a 3-cylinder Yanmar in my JD750. I replaced the fuel filter this past weekend so I was reading the bleeding procedure. The process described was a little complicated. The manual lists a series of steps, in about three different parts of the fuel delivery system, to be followed in a specific order. The instructions also mentioned some odd things, like NOT bleeding the line going to the middle injector.
    Maybe none of the parts are bad and you just need to bleed it a certain way?
  6. #16
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,168
    gilmer tx
    Bobcat CT235
    Still don't know the engine model, don't guess it matters but am I correct that is a priming pump below the injector pump and is it working?
  7. #17
    Gold Member
    Join Date
    Nov 2011
    Posts
    286
    Canton, TX
    JD 301A and yanmar YM2500
    Default
    There will be a model an sn on the side og the engine. On my ym2500 I believe it is on the left side of the engine.
  8. #18
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,168
    gilmer tx
    Bobcat CT235
    off the subject, but got to ask medic0648, were you an army medic?
  9. #19
    Join Date
    Apr 2013
    Posts
    14
    Bushnell, FL
    Quote Originally Posted by sshaw View Post
    I don't have a manual for the tractor, but I'm 99% sure I have bled it out correctly based on all the Google searches I have done before posting a thread on this site. I'm fairly well versed in working with the larger diesels, especially the old Detroit's. I started at the fuel filter, and worked my way up the line all the way up to the injectors. No signs of air anywhere in the system.
  10. #20
    Join Date
    Apr 2013
    Posts
    14
    Bushnell, FL
    Quote Originally Posted by winston1 View Post
    I had put in my original post that it was a 3T series engine. I scraped some paint off the tag on top of the valve cover and was able to decipher....3TN75. You're correct there is a priming pump below the IP. It seems to function fine. When I break the inlet banjo fitting, fuel pours out, and when I press the primer lever on the primary pump with the fitting still open, the fuel really comes out. I pulled the cover on the primer pump thinking there might be a screen filter inside, but no such luck. I don't think I have any restriction issues going into the IP.
Similar Threads
  1. STX 38 running problems
    By rosey65 in forum John Deere Lawn & Garden
    Last Post: 02-25-2012, 10:54 PM
  2. yanmar not running!
    By true4u in forum Yanmar
    Last Post: 07-19-2011, 12:00 AM
  3. Running Problems MF 65
    By mvm91861 in forum Parts/Repairs
    Last Post: 04-30-2011, 08:05 PM
  4. More Over-Running Clutch Problems
    By tderrick in forum General Vintage Tractors
    Last Post: 10-04-2009, 01:29 PM
  5. Running Problems
    By fancherf in forum Chinese Tractors
    Last Post: 09-11-2006, 12:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
