Results 21 to 26 of 26
04-23-2013, 11:09 PM #21
- Join Date
- Apr 2013
- Posts
- 3
- Location
- TX
- Tractor
- JD 950/ YM2000
Re: Today's project - fuel gauge in cap.
here you go... Hoye Tractor & Equipment Parts
Yanmar Tractor Parts: FUEL CAP GAUGE LENS
FUEL CAP GAUGE LENS
FUEL CAP GAUGE LENS Code: H194145-04351
Our Price: $6.54
04-30-2013, 04:54 PM #22
- Join Date
- Apr 2008
- Posts
- 51
- Location
- Western Massachusetts
- Tractor
- YM 276D
When I had mine apart I didn't have any solvent so I tried the wife's nail polish remover to clean the inside of the lens and then I think I put a coat of clear fingernail polish on. Still looks pretty clear after five years.
05-03-2013, 01:26 PM #23
Well, I managed to run out of fuel while mowing yesterday, and I was as far as I could be on my property from where my completely full (and heavy) 6 gallon gas can was at. I had to walk back and forth twice becuase I discovered that the screw in the banjo fitting I needed to loosen (to bleed the fuel down) couldn't be turned with a screwdriver because of paint. All of this to say that I'm thinking again about how NICE it would be to have a fuel gage on my cap!
Yanmar YM2210, Taylor-way 5' finish mower, Woods 4' rotary mower, boom pole, hayride wagon; upgraded tractor with gas turbine engine plus strap on solid rocket motors for that extra boost of speed... but brakes only work when I'm on the ground.
05-03-2013, 02:17 PM #24
- Join Date
- Jan 2004
- Posts
- 10,016
- Location
- Sonoma County
- Tractor
- Yanmar YM240, and now just one YM186D
03-01-2018, 01:59 PM #25
- Join Date
- Sep 2016
- Posts
- 2
- Location
- Eaton Rapids, MI
- Tractor
- Wheel Horse 312
The older style "Indicator Gas Cap lens" is also available, just $5 @ (1/3 ounce) + shipping:
GlenPettit@iCloud.com (13/4" diameter, fits Kelch caps+)
03-01-2018, 02:04 PM #26
- Join Date
- Sep 2016
- Posts
- 2
- Location
- Eaton Rapids, MI
- Tractor
- Wheel Horse 312
To clean the outside of your clear gas cap lens that has yellowed; Toothpaste works great, especially if it has an abrasive in it, or use Rubbing Compound. It is very difficult to remove these lenses from the gas cap since they used 'super glue' to install them and an older lens has dried and is prone to cracking and shattering when removed, so we can't really clean the underside. Sometimes, older flashlights have this same diameter lens and will replace into the cap. The gauge face and dial can also be cleaned this same way.
Similar Threads
Homemade Aluminum Diesel Fuel Transfer Tank-Fuel Cap/Weld-in Fitting?
By LanceH in forum WeldingReplies: 14Last Post: 09-04-2017, 10:52 PM -
99 f350 fuel gauge died, 00 yukon fuel gauge died.
By Soundguy in forum Parts/RepairsReplies: 11Last Post: 01-01-2013, 06:59 PM -
Today's Project Time
By CompactTractorFan in forum Related TopicsReplies: 25Last Post: 07-02-2011, 10:18 PM -
Oil & Fuel Fuel cap with gauge on YM1700
By BTackett in forum YanmarReplies: 5Last Post: 08-02-2008, 08:58 PM
