Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    Super Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    7,636
    The Heart of Dixie
    Yanmar3110D, Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
    Default Re: Yanmar 336 ... Three point hitch lift arms not working
    yes, it would have been nice to have had a return in the side like that. I can't offer anything as, my hoses aren't routed like this
    A Fredricks Yanmar 3110D
    07 Dodge 2500 5.9 Cummins
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    North Star 4 K PSI pressure washer
    Honda 300 4 trax
    Yamaha Timberwolf
    liquid logic coupe kayak
    16' Tow Master Dump Trailer ,20' Yanmar Hauler
  2. #12
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Here ya go I found a pic of the draft clutch lever in my attachments and the lever is down to work with the 3pt draft control so yours is wrong now and may be why it isn't working?. I will dig around or take some more tonite for ya. You even may find some pics in a thread I started about remote hydraulics I put on mine last year or year before.
    http://www.tractorbynet.com/forums/a...-1024x768-.jpg
    A thread on 3810/3110/336 hydraulics..doubtful anything of interest but I ran across it none the less thought it may reveal something?
    http://www.tractorbynet.com/forums/y...ng-loader.html
    For the life of me I cant find the aux hydraulics thread I mentioned its related to a 3pt log splitter I converted from a self powered but it alludes me....
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  3. #13
    Join Date
    Jun 2010
    Posts
    1,463
    Southern California
    International Harvester 284, Yanmar 1401D, Yanmar 240...etc
    Quote Originally Posted by Car Doc View Post
    Is it this one? http://www.tractorbynet.com/forums/h...tter-guru.html
  4. #14
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Yes thanks 284 that is it thank you!
    I went and looked thru that one just now and I was thinking I had better pictures of the 3pt block with what the 2 lines were in and out? Loosing my memory isn't a new thing haha. The ones that are in the OP pics. I can take more tonite so I can say which one is in and which is out.
    Here we go I found it. The H is actually an I for in I was sideways when I wrote it or something haha. The O is pressure I is return.
    http://www.tractorbynet.com/forums/a...-1280x960-.jpg
  5. #15
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    fwtw off topic sorry but I wont be back here until late tomorrow. I forgot I was taking my wife on the motorcycle for a root canal out of town at the crack of dawn. I will get those other pics on here late tomorrow for ya.
  6. #16
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Ok here is the pics of mine and my 3 pt works fine with all these levers and so on where they are in the pics. The lever on the lower left of the rock shaft housing is supposed to do something but I cant find the description right now? Suffice it to say if yours is up like mine in the pic it should work. hth
    edit: Like I mentioned the lever on the rt side rock shaft on yours shows its up that is for auto draft and will not work with the draft control lever it will not work that is the first thing I would do is flip it down!
    Attached Thumbnails Attached Thumbnails Yanmar 336 ... Three point hitch lift arms not working-img_1295-1280x960-jpg   Yanmar 336 ... Three point hitch lift arms not working-img_1294-1280x960-jpg   Yanmar 336 ... Three point hitch lift arms not working-img_1291-1280x960-jpg   Yanmar 336 ... Three point hitch lift arms not working-img_1293-1280x960-jpg
  7. #17
    New Member
    Join Date
    May 2013
    Posts
    14
    Alice, TX
    YM336D, Farmall M, Int 560D, JD 4020D
    changed controls to photos but still nothing.
  8. #18
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    Ok that's where we had to start. The next thing I wonder about is whether the hp line back to the 3 pt block is dumping into a return? Reason I even say this is your p/s is working and it is feed by a separate port on the pressure regulator/diverter block.
    The hp feed to the 3 pt is the steel line going back from that block so if its been opened there could be a routing issue. A person needs to follow the flow to determine that the pics dont show how the hoses and lines are. hth
  9. #19
    New Member
    Join Date
    May 2013
    Posts
    14
    Alice, TX
    Cleaned hydraulic screen and still no movement on 3 point lift. :-(
  10. #20
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,250
    gilmer tx
    Bobcat CT235
    Quote Originally Posted by jsal007 View Post
    Just for fun with the tractor idling why don't you "slowly" crack the banjo fitting under the control valve (shown in your first picture) just to assure you are getting flow to the 3 point control valve? Might be a little messy but with no load I don't thing anything dangerous. Just an idea.
Similar Threads
  1. Replies: 3
    Last Post: 05-22-2013, 02:57 PM
  2. 5083e 3 point hitch pulsates with a load on the lift arms.
    By toplineredangus in forum John Deere Owning/Operating
    Last Post: 05-04-2013, 09:44 PM
  3. How low do your category 0 3-point hitch lift arms go?
    By SilverLakeFab in forum Attachments
    Last Post: 04-04-2013, 11:27 PM
  4. Replies: 2
    Last Post: 12-29-2012, 07:09 PM
  5. Three point hitch lift arms not working
    By mchild in forum Parts/Repairs
    Last Post: 11-15-2005, 09:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
