Page 8 of 10 FirstFirst ... 5678910 LastLast
Results 71 to 80 of 94
  1. #71
    Platinum Member Neat 1500's Avatar
    Join Date
    Aug 2009
    Posts
    851
    Melbourne,Australia
    Yanmar YM1500 Red & YM14 MkII
    Default Re: Help with new ym226D purchase
    sounds as if it is the switch, no confusion there...
    Paul YM1500 & YM14 MkII
  2. #72
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,175
    gilmer tx
    Bobcat CT235
    Quote Originally Posted by Smoody View Post
    Now I'm confused...with key in on position. Dashlights light up..I can jump from small wire(ignition) wire on top of solenoid to starter and it cranks. Now maybe I don't understand how a switch works, if in the on position. 12.6v at the selonoid would fire the solenoid, what actually happens once you turn to key to Start? I though the power was transferred to the solenoid at that moment.
    There should be 0 volts at that small wire on the solenoid until the key is turned to the crank position, not the on position. I think that is what we are both saying.
    One large wire on the solenoid comes straight from the battery. If you are jumping from that wire to the small wire and it turns over every time that is saying your solenoid is good.
    Not meaning to confuse you.
  3. #73
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,547
    Greenwood Co., SC
    Yanmar YM2000
    By doing what you just described your taking the switch out of it!! That just tells you the solonoid is working! All your doing is manually being the switch with your hand and that wire. The switch for it to actually start will momuntarily take "always hot " connection and as u turn it complete a circuit sending power to the solonoid allowing it to switch the power internally to the starter.
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  4. #74
    Platinum Member Smoody's Avatar
    Join Date
    May 2008
    Posts
    629
    South Carolina
    YM226D
    I need to put a new fan belt on , quicker to remove water pump or radiator to get it on?
    YM226D w/YFL800 Loader
  5. #75
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,175
    gilmer tx
    Bobcat CT235
    I don't guarantee it, but I don't think you have to remove either. I believe if you loosen the dynamo, disconnect the bottom radiator hose at the radiator, you can then remove the belt. It is a little tricky getting it around the fan and shroud but it will come out of there.
  6. #76
    Super Member California's Avatar
    Join Date
    Jan 2004
    Posts
    9,585
    Sonoma County
    Yanmar YM240, and now just one YM186D
    And - Don't mess with the water pump.
    Maybe loosen the radiator holddowns and tilt it forward? You might have to loosen the fan from the pump to tilt its blades too.
    I did this project on the YM240 when I bought it but don't remember the details. It wasn't particularly difficult.
  7. #77
    Join Date
    Sep 2009
    Posts
    8,547
    Greenwood Co., SC
    Yanmar YM2000
    i put it on my 2000 easy, you can loosen the alternator.
  8. #78
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    I just have to remove one end of a lower hose to chg belts its a pain but needs done so we do it.
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  9. #79
    Join Date
    Jan 2012
    Posts
    1,112
    YM2000
    Fan Shroud for theo 2000. Then you can easily get the belt around the blades and water pump. 2 10mm I believe on the top.
    My bad guys something told me to go out and look I had to remove the Water Pump Hose als. Philips head or 10mm at the Pump. Used a Bucket to catch what little bit of Anti-freeze. Only took a Sec.
  10. #80
    Join Date
    Jan 2004
    Posts
    9,585
    Sonoma County
    Any news? What did it take to get the belt in there?
Similar Threads
  1. YM226D PTO
    By KFree in forum Yanmar
    Last Post: 02-22-2009, 09:58 AM
  2. PTO Shield YM226D
    By ancientlake in forum Yanmar
    Last Post: 04-09-2008, 02:59 PM
  3. YM226d value
    By stonecutter in forum Yanmar
    Last Post: 10-18-2007, 06:54 PM
  4. FEL for YM226D??
    By JIMTORL in forum Yanmar
    Last Post: 06-06-2005, 11:54 AM
  5. YM226D Won't come out of 4WD
    Last Post: 06-03-2005, 11:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
