Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 78
  1. #21
    Super Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    7,616
    The Heart of Dixie
    Yanmar3110D, Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
    Default Re: Drive train YANMAR FX24D
    Amazes me how some people are able to dig this stuff up. I can only hope for that type knowledge some day Good work nevis
    A Fredricks Yanmar 3110D
    07 Dodge 2500 5.9 Cummins
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    North Star 4 K PSI pressure washer
    Honda 300 4 trax
    Yamaha Timberwolf
    liquid logic coupe kayak
    16' Tow Master Dump Trailer ,20' Yanmar Hauler
  2. #22
    New Member
    Join Date
    Sep 2013
    Posts
    17
    Winnsboro, TX
    yanmar fx24d
    It is indeed amazing that some people can pull the magic out of an entry from years gone by. I night remember for a couple of days. Unless it goes back to something from 60 years ago, then I will remember some of the really useless info.
  3. #23
    Member
    Join Date
    May 2006
    Posts
    39
    England
    Yanmar F215
    I bought my F215 in 2006 and Tractor Ernie was very knowledgeable about the F series tractors and very helpful concerning questions I had about this tractor so I always tend to remember posts from him.
  4. #24
    New Member
    Join Date
    Sep 2013
    Posts
    17
    Winnsboro, TX
    yanmar fx24d
    Winston1 came by today and we loaded my tractor on his trailer to go to Gilmer. The 25 miles over there to work on it in his shop is preferred to trying to work on the ground under a shade tree. Hopefully we can get enough photos and commentary posted to give the next guy a little help.
  5. #25
    Join Date
    Oct 2002
    Posts
    813
    Pomfret,Connecticut
    yanmar 336d w ldr,Cub,many attachments
    kinda nice to be that close and able to tag team it, the ring is probably fine,its the pinion thats the weak part but who knows til you have a close look. Looking fwd to the prognosis....Thanks for sharing gents !!
    From CT
  6. #26
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,225
    gilmer tx
    Bobcat CT235
    Here is a couple of pictures after removing the loader, lowering the roll bar and parking her in the garage. Might not have to remove the loader but just not sure how far this tear down is going so I figured now might be better than later. I just took the inlet and outlet to the loader control valve off and put a coupling between them to complete the hydraulic circuit. I'll be posting as we go and welcome any input.
    Attached Thumbnails Attached Thumbnails Drive train YANMAR FX24D-100_6383-jpg   Drive train YANMAR FX24D-100_6382-jpg
  7. #27
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,225
    gilmer tx
    Bobcat CT235
    Moving along but with a problem. Turns out the problem is the ring gear to carrier bolts have been sheared off plus the ring gear has one broken tooth which renders it useless in my book. Wondering if the tooth might have broke and wedged causing the bolts to shear? The 276 manual Hoye sent doesn't have many similarities with the fx24d. The right axle housing is going to have to come off. As you can see from the picture is is one piece and inside it is the brake drum. I am wondering if this housing can be unbolted and removed or do I have to start removing the outer gear housing? Anybody out there have a fx24d parts manual that could possibly post the drawings of that assembly?
    The first picture is showing the axle housing. If anybody out there has drawings or knowledge just how that comes off I'd sure appreciate a holler. The two pictures after that shown the broken tooth on the ring gear, the one looking straight down on the ring gear just showing there are no bolts holding it to the carrier.
    Big difference in the fx series from the ym series is the pto gearing is not on the rear of the differential housing. There is not even a cover on the rear. All the pto gearing is in the front compartment of the housing. As you can see by the picture there is a middle partition in the housing.
    Attached Thumbnails Attached Thumbnails Drive train YANMAR FX24D-100_6393-jpg   Drive train YANMAR FX24D-100_6392-jpg   Drive train YANMAR FX24D-100_6391-jpg   Drive train YANMAR FX24D-100_6385-jpg   Drive train YANMAR FX24D-100_6387-jpg
    Drive train YANMAR FX24D-100_6389-jpg   Drive train YANMAR FX24D-100_6390-jpg
  8. #28
    Join Date
    Jan 2012
    Posts
    1,118
    YM2000
    Drive train YANMAR FX24D-fx24-rear-jpgDrive train YANMAR FX24D-fx24-rear-jpgThis may help winston. Looks to be Bolts to the Gear and A Roll Pin in the #4 Spider Gear Shaft. I believe I see the Pin but the bolts ?. Oh here's the axle I believe it's just a snap ring. It may not even be close but worth giving it to you if it helps....
    Attached Thumbnails Attached Thumbnails Drive train YANMAR FX24D-axle-fx24-jpg
  9. #29
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,225
    gilmer tx
    Bobcat CT235
    Quote Originally Posted by careyo63 View Post
    Thank you Carey. That is more than I had. I'm going to go have another look.
  10. #30
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,225
    gilmer tx
    Bobcat CT235
    Thanks to Carey's pictures I got up enough courage to take the axle housing bolts out and sure enough both sides just slide right out of the differential carrier splines. This thing has wet disc brakes. In the picture of the axle housing I just slid out the brake disc a little for picture purpose.
    Attached Thumbnails Attached Thumbnails Drive train YANMAR FX24D-100_6396-jpg   Drive train YANMAR FX24D-100_6395-jpg   Drive train YANMAR FX24D-100_6394-jpg
Similar Threads
  1. Yanmar FX24D
    By KDOregon in forum Oil, Fuel & Lubricants
    Last Post: 08-07-2012, 09:36 PM
  2. Need Help from All L245DT Drive Train?
    By fbson395 in forum Parts/Repairs
    Last Post: 01-30-2011, 10:21 PM
  3. Yanmar FX24D
    By renegadem in forum Yanmar
    Last Post: 04-06-2009, 09:34 PM
  4. Yanmar FX24D headgasket bolt torque
    By Kyjeeper in forum Yanmar
    Last Post: 09-04-2008, 05:24 PM
  5. ? on yanmar fx24D
    By wendelin in forum Yanmar
    Last Post: 11-01-2004, 08:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
