Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Mar 2002
    Posts
    109
    Eastern Ala
    Many different models
    Default 1610D Throttle
    Does anyone have a1610D that could shoot me photo of the throttle hookup. I took mine loose rebuilding the engine and have forgot
    how to reassemble. I can't figure the return springs works.
    Tractorman
  2. #2
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,168
    gilmer tx
    Bobcat CT235
    Default Re: 1610D Throttle
    Figure it is real similiar to this 1510. Will this help any? Yanmar Tractor Parts: THROTTLE
  3. #3
    Join Date
    Mar 2002
    Posts
    109
    Eastern Ala
    Thank you, the one I have is not the same, already been that route.
    Tractorman
  4. #4
    Super Member houstonscott's Avatar
    Join Date
    Dec 2010
    Posts
    9,117
    Oglesby, Texas
    Kubota L3800, Kubota GR2120, Kubota RTV1100, Kubota 5100sc
    Default
    Can I ask how you tighten the throttle. I have a 1610 and the throttle wants to return to slow will not stay where set, just drifts to slow.
    HS
  5. #5
    Veteran Member deepNdirt's Avatar
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    Quote Originally Posted by houstonscott View Post
    HS
    Had the same issue with my 1700 when I first got it, I think the 1610D is slight different from the 1700,
    I wound up having to install a longer bolt and installing a larger washer and locking nut, I tightened the nut snug and then backed off slightly, then installed a 2nd nut tight against the locking nut to keep it from backing off, might not be the correct fix although has worked for over 4 years now,
    Never judge a man until you've walked a day in his shoes,
  6. #6
    Join Date
    Jan 2012
    Posts
    1,109
    YM2000
    1610D Throttle-picture-025-jpgNot sure about the 1610 but there's a Nylon Friction Disc. in my YM2000 Throttle. You can see it in between the metal plates in the pic. Be careful when you tighten it up.I broke the Threads off mine when I first bought it and was having the same Prob. Lucky for me I was able to Weld them back. I still believe and pretty sure the Previous owner damaged it over tightening it since the Nylon Washer "Fric. Disc." was microscopic and desinagrated into pieces when taking it apart.
  7. #7
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    Carey, you see that short bold that has no nut on it... this is where I installed a longer bolt and a large washer so that it would go over the base of the lever ( the flat round part ) this fix kinda resolves the friction disk issue you speak of,
    Here is a pic of what I have done,
    Attached Thumbnails Attached Thumbnails 1610D Throttle-img_10000-jpg
  8. #8
    Join Date
    Jan 2012
    Posts
    1,109
    YM2000
    I already broke it Hah!!! When I checked and found out the price of a new Linkage and was lucky enough to repair my Handle. For a 3 dollar Disc. that I recieved the next day in env. Reg. mail. I decided to go that route before I tore something else up. LoL. I also put a Nut and Large Washer on the short bolt to hold it snug and just used the pedal to get me through until I recieved it.
  9. #9
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    3,246
    Kansas
    YM3810D Yanmar
    I know a guy with a 1610d if a pic doesn't show up here I will get one for ya.
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  10. #10
    Join Date
    Jan 2012
    Posts
    1,109
    YM2000
    [QUOTE=houstonscott;3479626]Can I ask how you tighten the throttle. I have a 1610 and the throttle wants to return to slow will not stay where set, just drifts to slow.
    Just snug up and lock the Nuts. It uses the same fric. disc. as the Pics.1610D Throttle-fric-disc-jpg
Similar Threads
  1. Replies: 2
    Last Post: 06-22-2012, 02:05 AM
  2. 1610d won't go,help
    By dbloyd in forum Yanmar
    Last Post: 11-07-2008, 03:38 PM
  3. converting hand throttle to foot throttle on 1500
    By Cherokee_John in forum Yanmar
    Last Post: 04-13-2006, 08:49 PM
  4. 1610D throttle and white smoke
    By Eric5444 in forum Yanmar
    Last Post: 04-09-2002, 10:47 AM
  5. foot throttle and hand throttle
    By ket in forum Yanmar
    Last Post: 04-09-2002, 02:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
