Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Kingsland Ga
    Yanmar 1810
    Default 1810 won't move and no PTO
    Used about 20 minutes disengaged PTO and drove across road tried to engage PTO nothing happened and won't move forward or reverse. Hyd lift still works?
  2. #2
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,175
    gilmer tx
    Bobcat CT235
    Default Re: 1810 won't move and no PTO
    clutch or splined coupler on main drive shaft are possibilities.
  3. #3
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Kingsland Ga
    Yanmar 1810
    I'm leaning toward clutch just not familiar with hydrostatic transmission the mower would start slow and then speed up eventually even though it didn't seem to effect speed of tractor and then next time I engaged PTO nothing?
  4. #4
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Kingsland Ga
    Yanmar 1810
    How difficult to split tractor and replace clutch and is there a way to be sure before splitting tractor?
  5. #5
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,175
    gilmer tx
    Bobcat CT235
    The way the 1810 is built the main drive shaft goes through the transmission and then to the pto. If you have no drive and no pto it has to be the clutch or couplings in my opinion. Is your clutch pedal adjusted properly? You should have around 5/8" freeplay at the top of the pedal before you feel contact. You can first make sure that is correct and if so I'm thinking a split is going to be in order. Here is Hoye's article. Yanmar Tractor Clutch Replacement
    Wait for others to respond. Don't split it on my advice alone. I've been known to give bad advice.
  6. #6
    Join Date
    Oct 2002
    Posts
    813
    Pomfret,Connecticut
    yanmar 336d w ldr,Cub,many attachments
    did u check to be sure all the range selectors r in gear ? Re trace prior to losing driveability to see if something simple occurred,just a thought prior to disassembly,keep us posted
  7. #7
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Kingsland Ga
    Yanmar 1810
    Quote Originally Posted by grainger12002 View Post
    Looked at everything it's internal going to split and see ill let you know when I do.
Similar Threads
  1. Ym240d will not move and pto inop??
    By Dieselcrew in forum Yanmar
    Last Post: 03-08-2012, 10:31 PM
  2. cub cadet 1810 with blower near buffalo ny
    By Unregistered2013 in forum Cub Cadet L&G
    Last Post: 11-20-2008, 11:44 AM
  3. CC 1810 hydro release valve
    By cfw3 in forum Cub Cadet Tractors
    Last Post: 12-15-2004, 08:44 PM
  4. Oil & Fuel need fuel injection pump for 1810
    By Marv in forum Yanmar
    Last Post: 05-19-2004, 10:28 PM
  5. Case 1810 transaxel
    By TractorLuvr in forum Construction Equipment
    Last Post: 08-17-2003, 10:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
