Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
  1. #11
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    Default Re: Oil ran too low - Need to fill and bleed the system
    Quote Originally Posted by Neat 1500 View Post
    ... Maybe the plumbing is a bit screwed up? They installed the ball valve to get flow to the 3PH?
    That ball valve is brass, not steel. I don't know the hydraulic pressure on this tractor, but most of the brass valves like that I have seen in the US are only rated for 150 to 200 psi or so. Nowhere near typical hydraulic pressures.
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  2. #12
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,179
    gilmer tx
    Bobcat CT235
    Would your loader valve happen to have a tag identifying it? I have no idea what is going on there. If I am counting right the valve has 8 openings and you have 9 hoses coming off of it counting the one that has the tee. I suspect one of those openings is power beyond and should go back into the transmission sump. Other than the hoses going to the loader cylinders can you identify where the other hoses go? That should be 4 hoses.
    Good pictures. Thanks.
    Only reason a brass ball valve would be ok there is if that opening is the tank return line. A no pressure line.
  3. #13
    Super Member California's Avatar
    Join Date
    Jan 2004
    Posts
    9,628
    Sonoma County
    Yanmar YM240, and now just one YM186D
    Darn it that wasn't ready to post. [so I deleted it]. More clearly stated:
    I wonder if the ball valve shuts off the tank return line to redirect fluid (under pressure) to the 3-point.
  4. #14
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,179
    gilmer tx
    Bobcat CT235
    Quote Originally Posted by California View Post
    Darn it that wasn't ready to post. More clearly stated:
    Sort of what it sounds like but doesn't seem the correct way to be plumbed.
  5. #15
    Super Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    7,596
    The Heart of Dixie
    Yanmar3110D, Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
    1st 1 I've seen plumbed like that (with a ball valve in the circuit). You should be able to operate the 3 point without opening or closing a ball valve. Good looking tractor & loader. Who made the loader ?.
    A Fredricks Yanmar 3110D
    07 Dodge 2500 5.9 Cummins
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    North Star 4 K PSI pressure washer
    Honda 300 4 trax
    Yamaha Timberwolf
    liquid logic coupe kayak
    16' Tow Master Dump Trailer ,20' Yanmar Hauler
  6. #16
    Join Date
    Jan 2004
    Posts
    9,628
    Sonoma County
    The curved arms and the linkage on the bucket look like an OEM Yanmar loader that was offered to me by an importer.
  7. #17
    Member
    Join Date
    Nov 2013
    Posts
    27
    Taabinga Queensland
    Yanmar YM2310D
    Yes, on the loader there are no after-market plates or any numerals of any kind at all that I can find
    Which makes me think that the loader may well be original equipment
    About the hydraulics plumbing - I did a schematic diagram and tried to upload it here with no luck
    I'll take a photo of it and upload that
    I have a feeling that the third On/Off valve no longer functions as it should and the ball valve is a `patch'
    I'd sooner get the original set up going
    As it is, ths valve needs to remain open all the time.
    To lift the 3PL, I then need to close the ball valve with the 3PL lever in the Up position
    And the 3PL lever must be in neutral or the bucket controls do not work
    It all works but I feel it needs sorting out!
    Ideas?
  8. #18
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,179
    gilmer tx
    Bobcat CT235
    Oil ran too low - Need to fill and bleed the system-346697d1384920880-oil-ran-too-lowThe side view picture of the loader valve seems to show a tag. Could that be cleaned and made legible?
  9. #19
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,550
    Greenwood Co., SC
    Yanmar YM2000
    Quote Originally Posted by Redlander View Post
    Ideas?
    Thats not right? You should be able to move your bucket and adjust your 3pt at the same time. I dont have a loader but i have run tractors with them and these small yanmars i dont thing are plumed any different.
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  10. #20
    Join Date
    Jan 2004
    Posts
    9,628
    Sonoma County
    This is the tractor with what seems to be an original front end loader
    Attachment 346694Attachment 346694
    And this is the valve manifold
    The mystery valve is on the extreme right hand side in the picture
    Beneath it inline is the ball valve that needs closing to activate the TPL `lift'
    Attachment 346696
    I just put the following photos in a new thread (because nobody would ever find them in the future under this title).
    This loader was in the warehouse of a tractor importer here, in 2007. They said it is an original Yanmar-Japan loader and it came over with a YM2220 or similar size FX model. Mark (over on some other tractor board) said he has seen these before. Look familiar?
Similar Threads
  1. 720 ran out of fuel, how do i prime or bleed?
    By larson1951 in forum John Deere Owning/Operating
    Last Post: 06-04-2012, 02:24 PM
  2. TD95D Low fluid levels-low factory fill?
    By Jerry/MT in forum New Holland Owning/Operating
    Last Post: 01-20-2011, 12:50 PM
  3. TD95D Low fluid levels-low factory fill?
    Last Post: 01-19-2011, 09:39 PM
  4. Oil & Fuel Fuel system bleed
    By golfgooroo in forum Owning/Operating
    Last Post: 03-26-2009, 12:34 AM
  5. Can't seem to bleed fuel system
    By Pilot in forum Parts/Repairs
    Last Post: 05-05-2006, 06:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
