Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
  1. #21
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,217
    gilmer tx
    Bobcat CT235
    Default Re: Oil ran too low - Need to fill and bleed the system
    Interesting. Looks like a quick opeining valve on the lower side of that joy stick control valve. A red line right above it indicating a position of something when that valve is one way or the other. At least that's what it looks like to me.
  2. #22
    Member
    Join Date
    Nov 2013
    Posts
    27
    Taabinga Queensland
    Yanmar YM2310D
    Mmm .. yes that looks very similar to my loader all right.
    So the original set up may have been joystick controlled??? ... or does mine pre-date this joystick model I wonder?
    I'll get that picture of the piping posted over the weekend.
    It's our busiest time of the year here with the `wet' starting
  3. #23
    Member
    Join Date
    Nov 2013
    Posts
    27
    Taabinga Queensland
    Yanmar YM2310D
    OK, here is the sketch of the piping
    And on the manifold I found a painted-over plate
    "DEU-YN"
    "P-1285-03"
    Oil ran too low - Need to fill and bleed the system-my-ym2310d-hydraulics-controls_20131123_0002-jpg
    Levers 1 & 2 are the FEL controls - all OK
    Lever 3 must always stay `Down' for ANYTHING to work
    The Ball Valve 4 needs to stay open for the FEL to work
    With it open the TPL does not work no mater what I try
    Closing the Ball Valve 4, allows the TPL to work
  4. #24
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,217
    gilmer tx
    Bobcat CT235
    I am going to copy a thread over showing a 2310 3 point control valve openings. Maybe you can identify which opening your line is coming out of on the way to the ball valve. http://www.mytractorforum.com/showthread.php?t=90222
    Is the line going to the top of the transmission just a free flow return line? No pressure?
    Your loader tag confirms your loader and control valve are genuine Japanese.
    I know I am not offering anything to help but sure enjoying learning a little more. All the Yanmars I am aware of are plumbed with the pump discharge going through the loader control valve on the way to the 3 point control valve. Some with power beyond and some without. Yours seems to be just opposite.
  5. #25
    Member
    Join Date
    Nov 2013
    Posts
    27
    Taabinga Queensland
    Yanmar YM2310D
    Hello Winston1
    The line with the ball valve is coming from the top of the 3PL and is pressurised
    I looked at the weblink and yes, I have the exact same set-up on my 3PL, with the reserve inlet/outlet unused
    The top line in that picture is what goes forward, through the ball valve, and to the loader valve manifold
    The return to the top of the transmisson case is the line with the Tee in it (at the near/lower end of the manifold in my sketch)
    Thanks to your patience I have a better understanding of what might be going on - how's this?
    My third lever may be no longer functioning (it may be jammed always open)
    Hence the ball valve, now doing what the 3rd lever would do by stopping flow to within the 3PL circuit (cut off from the FEL controls).
    However, the 3rd lever has a return line, joining in at the Tee, and going back to the top of the transmission case
    So if it would cycle fluid via the 3PL, operating it.
    The ball valve is just a stop, fluid can only cycle inside the 3PL circuit locally at the 3PL, never reaching a return line - Ouch!
    I can feel the engine strain under the constraint - I first flick the 3PL lever to UP then I close the ball valve and quickly open it again
    I guess if I had a functional 3rd lever, it too would stop me using the FEL simultaneously, although it would return the fluid safely
    So it's may be a 2 step fix now for me
    1 Fix the 3rd lever and ditch the ball valve before I burst a line!
    2 Look if there is a (re-plumbing) plan where the FEL can be used regardless of the 3PL
    Cheers
    Bob
    Redlander
  6. #26
    Member
    Join Date
    Nov 2013
    Posts
    27
    Taabinga Queensland
    Yanmar YM2310D
    I've just re-read my last post and I must confess I am completely confused
    The Manual sent by Hoyes ended up in Canada on its way to Australia ... now being returned to Hoyes.
    So I'm in the dark
  7. #27
    Member
    Join Date
    Nov 2013
    Posts
    27
    Taabinga Queensland
    Yanmar YM2310D
    And running out of oil may have been a result of the oil being super pressurised within the 3PL circuit and finding its way out of small leaks
  8. #28
    Member
    Join Date
    Nov 2013
    Posts
    27
    Taabinga Queensland
    Yanmar YM2310D
    Could you point me in the direction please?
    Evidently I should be looking at re-doing the plumbing
  9. #29
    Super Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    7,616
    The Heart of Dixie
    Yanmar3110D, Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
    I Have the single joy stick style loader valve. I like it much better than having a dual lever control valve. Most (if not all) newer tractors have the single lever style. If you could get a single lever ,I think you would be much happier with your loader. Mine is plumbed as Winston described
    The HP (High pressure) line coming off the hyd pump is cut. An adapter is installed on the steel line. Attach a rubber hyd hose to this adapter on the hp line. Route this hyd hose to the inlet of an open center loader valve. at this point you have supplied High pressure to your loader valve. Connect your other hoses to the loader work ports. the outlet on the valve will go to the tank (or return). Assuming this loader valve has a PB (power beyond) port Come out of the pb with a hose and feed the hp line to your 3 point . If you buy a new loader valve. be sure to buy if with a pb port and get the pb sleeve
    A Fredricks Yanmar 3110D
    07 Dodge 2500 5.9 Cummins
    Husky 372xp
    Husky 55 Rancher
    Maruyama trimmer
    Husky trimmer
    Redmax BP blower
    Toro zero turn
    North Star 4 K PSI pressure washer
    Honda 300 4 trax
    Yamaha Timberwolf
    liquid logic coupe kayak
    16' Tow Master Dump Trailer ,20' Yanmar Hauler
  10. #30
    Elite Member
    Join Date
    Dec 2009
    Posts
    4,217
    gilmer tx
    Bobcat CT235
    Quote Originally Posted by Redlander View Post
    This is complicated and I don't want to give you advice that might do harm. Anything I say here is only speculation and not fact. Wish I could drive over and look at it with you.
    I am still not completely clear which opening on the 3 point control valve goes to the ball valve. Not sure if your saying it is the top hose shown in the picture I attached? I will attach a scan with instructions about the plug mentioned in that thread. Not sure yours is installed or not.
    I sure don't understand your loader control valve. I will also attach a sketch of a simple loader valve plumbing. I'm thinking I need to back off with all my speculations before I steer you the wrong direction. My daddy always said "You learn more when listening than when talking". Evidently, I didn't take that to heart.
    Attached Thumbnails Attached Thumbnails Oil ran too low - Need to fill and bleed the system-scan0001-jpg   Oil ran too low - Need to fill and bleed the system-scan0009-jpg
Similar Threads
  1. 720 ran out of fuel, how do i prime or bleed?
    By larson1951 in forum John Deere Owning/Operating
    Last Post: 06-04-2012, 01:24 PM
  2. TD95D Low fluid levels-low factory fill?
    By Jerry/MT in forum New Holland Owning/Operating
    Last Post: 01-20-2011, 11:50 AM
  3. TD95D Low fluid levels-low factory fill?
    Last Post: 01-19-2011, 08:39 PM
  4. Oil & Fuel Fuel system bleed
    By golfgooroo in forum Owning/Operating
    Last Post: 03-25-2009, 11:34 PM
  5. Can't seem to bleed fuel system
    By Pilot in forum Parts/Repairs
    Last Post: 05-05-2006, 05:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
