kfin
The 4 wd has stopped working on my 2310d. The lever by your left foot just swings back and forth. And also if you push the tractor it makes a "clunk" sound, does it when running also but you cannot really hear it. If you put your hand on the "pipe housing" part that runs underneath the tractor from where the 4wd lever goes to the front of the tractor you can feel it hitting each time it makes the noise. Something in there is loose.....not sure if this would be the same issue or separate.
Any ideas? Which manuals would I need to figure this out?
Thanks
Keith
Thanks
Keith
