Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    New Member
    Join Date
    Mar 2015
    Posts
    5
    Nashville, TN
    Yanmar YM1700
    Default New Member -YM 1700 transmission dipstick length
    Hi all,
    Bought a 1700 a couple months ago as my first tractor and have enjoyed getting to know it.
    My transmission dipstick is missing and i'm wondering if someone with a 1700 could measure the dipstick and respond with specs i could then use to glue a rod into the cap i have
    unless there's some reason i absolutely should buy a used one from hoye for around $30
    i suppose theres a chance the dipstick is down in there somewhere, so im planning on fishing around with a retrieving magnet first...
    ive had a slight issue with the hydraulic system so it would be nice if i could at least check the level
    thanks in advance!
  2. #2
    Bronze Member byronlj's Avatar
    Join Date
    Feb 2012
    Posts
    97
    White Mountains, AZ
    yanmar 169D
    Default Re: New Member -YM 1700 transmission dipstick length
    I believe there were two styles of caps. One with, one without dipstick.
    Dave
  3. #3
    Join Date
    Jul 2014
    Posts
    905
    Guin, AL
    Kubota L3200DT w/LA524, 5' Cutter, 5' Tiller, Pallet Forks
    To TBN from Alabama. If yours is without the dipstick, then I would think that getting one with a dipstick would be very easy.
    US Air Force Retired (1966-1988)
  4. #4
    Elite Member
    Join Date
    Dec 2009
    Posts
    2,902
    gilmer tx
    yanmar 2002d
    Welcome to the forum.
    Part #194150-24290 is 33mm x 184 long. Translates to 7.24409". I measured my 2002D dip stick 194190-24290, 33mm x 157, 6.1811". The 157 measurement on my dip stick is taken from the very bottom of the plastic screw in part to the very end of the dip stick. Starting at the very bottom of the dip stick and coming up about 11/16" is cross hatched and indicates approved level. Hopefully someone will measure the 1700 dip stick for you so there will be no question.
  5. #5
    Join Date
    Jan 2012
    Posts
    616
    YM2000
    -2000-hyd-trans-dipstick-jpg
    The 1700 and the 2000 use the same DS. This is my Ym2000. If you remove the Rubber Washer It's 8". Or 23 cm.
  6. #6
    Elite Member
    Join Date
    Dec 2009
    Posts
    2,902
    gilmer tx
    yanmar 2002d
    Default
    Quote Originally Posted by careyo63 View Post
    Guessing it is also 184mm from the bottom of the thread area. Everyone probably already knows this but the level is to be checked with the dipstick resting on the threads and not screwed in.
  7. #7
    Join Date
    Jan 2012
    Posts
    616
    YM2000
    Quote Originally Posted by winston1 View Post
    Could be that's why I measured it in CM. also. I'm not good for anything much over 21 using my pointer. I run out of Fingers and Toes you know.
  8. #8
    Silver Member silvertramp's Avatar
    Join Date
    Feb 2010
    Posts
    221
    W. MA.
    Yanmar 276D
    Looks like the one on my 276D. Don't know if the length is the same.
  9. #9
    Super Member deerseeker001's Avatar
    Join Date
    Jul 2011
    Posts
    7,722
    Central wisconsin
    International 2500a with Loader
    Welcome from Wisconsin
    ::welcome :::RON
    never stop learning.
  10. #10
    Elite Member
    Join Date
    Dec 2009
    Posts
    2,902
    gilmer tx
    yanmar 2002d
    Quote Originally Posted by silvertramp View Post
    Same part number for the 2000 and 276.
Similar Threads
  1. Ford 1900 dipstick length
    By cdcasias in forum Oil, Fuel & Lubricants
    Last Post: 06-10-2014, 03:13 AM
  2. Loader Transmission/Hyd dipstick
    By blackie65 in forum Kubota Owning/Operating
    Last Post: 12-20-2012, 02:23 PM
  3. Dipstick length for Iseki TA320
    By tom koenig in forum Iseki
    Last Post: 01-28-2009, 12:59 PM
  4. Transmission dipstick question
    By MarkLeininger in forum Kubota Owning/Operating
    Last Post: 11-11-2008, 10:01 AM
  5. anyone need a oil dipstick for a 1700
    By Soundguy in forum Yanmar
    Last Post: 02-23-2006, 04:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
