loving
I have a front end loader on my YM1500D that was scabbed on. The pump appearantly has two outputs, one goes to the hitch, one to the control valve for the loader. The return from the loader tees into the return from the hitch, then the return line goes to the pump.
One of the support columns for the loader is a tank, with a fill at the top and drains at the bottom. It leaks a little at the bottom, but I've been dilegently topping it off as long as I've owned the trackor.
Imagine my chagrin to find that none of the hoses connect with this 'tank'! I've been lugging around a couple quarts of fluid for nothing!
But now I am puzzled. Where is the reservoir on this system? It's got to have one somewhere, right? The hitch and loader both work as expected (but not at the same time, the hitch must be all the way up before any power gets to the loader)
Should I plumb the loader's tank into the return line? That tee is leaking and I want to fix it up right.
