woolyAcres
Now that the temperatures have dropped in my area I need to figure out the proper procedure for cold weather starting. What's the proper way to start these engines in cold weather (below 32F, and below 10F)?
The rod connected to my decompression lever is bent such that I can rotate the decompression lever 90 degrees without actually moving the lever connected to the other end of the rod. It basically slips. If I want to use decompression I have to open the hood and move that lever on top of the engine by hand. Being honest, I don't often use decompression to start it, because the lever on the top of the engine is so stiff it requires pliers to move.
The follow-up question to this is what is the principle behind the thermostat device? Does it require fuel to be useful, or can one use the thermostat and decompression without adding diesel to the fuel cup? Simply warming some input air. I ask because the hose from the fuel cup to the nipple on the thermostat device is missing, as is the cap for the fuel cup. I'm sure I can get that hose at the local auto parts store so if that's the best way forward I can solve that.
I'm lucky enough to have a block heater and have been using that when I need the tractor and it's 'cold' (below 45) but the shed where I'll keep her parked this winter doesn't have electricity so the block heater becomes less useful.
Does anyone have experience with these in cold weather? How do you operate/start it?
Thanks
Thanks
